Torque spec for the F/R brake caliper bolts??
Anybody have the Torque spec for the F/R brake caliper bolts?? Changing rotors and pads for march 10,11 HPDE. Thanks.
Mike.
Mike.
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
http://www.eliteengineeringusa.com/C6_Torque_Specs.pdf
print it, laminate it, keep it in your toolbox!
Year of car?? There are variations in the torque values for the caliper abutment brackets based on the year. The C4's have two values based on the year.
You get what you get
Finally done and washed up! Your right about the access. Depending on what wheel you're working on, it is difficult to get a long torque wrench into a position where you can push hard. It's pretty deep into the well. I used blue locktite and got about 110 ftlbs on them. I'm not 25 anymore and thats all I could push w/o tearing something. 110 ftlbs is a pretty tight though.
Thanks for the help guys.
BTW, I installed Centric Premium high carbon blank (no slots or holes) rotors and Carbotec XP10/XP8 pads.
I dont use locktight and just hit it with the wrench. Maybe you have the feel for the steel too. Ive never tq'd lug nuts either
