anyone here run a ls3 block with a batwing?
I have an ls3 block, l92 heads, but a ls6 oil pump and ls1 batwing oil pan. On slicks, should i still have the ls3 oiling issues?
I have the LS3 motor with the C5 bat wing and have seen no press drops in autox pulling some high G readings, but they were not long duration corners as I dont open track. I have done some sustained turns doing some skidpad testing and the readings never dropped
