Anyone Running 315's on Front of C6Z?
Old 03-02-2012, 10:37 PM
stevethe6th
stevethe6th's Avatar
Default Anyone Running 315's on Front of C6Z?
I have been running Kumho 710's on my '07 C6 Z06 for DE events. Sizes have been 285's and 335's on the stock front and rear rims respectively. I just acquired a set of C5 Z06 rear rims to use on the front allowing me to go up to a 305 or 315 front tire size. My question is this - does anyone have experience with the 305 or 315 Kumho 710 on the front? Do the 315's fit without clearance issues or should I play it safe with the 305's?
Thanks in advance for your feedback.
Old 03-02-2012, 11:25 PM
Gman57
Gman57's Avatar
I don't run the Kumho but have no issues with 315x18 Hoosiers. Mounted on my CCW or Forgeline wheels.
Old 03-03-2012, 08:07 AM
mcar00
mcar00's Avatar
315's can be used on the front of the C6 Z06 given the proper wheel but I think your issue is not one of tire size but wheel offsets. I would try to compare the dimensions and offsets of the C5 Z06 rear to a CCW 11X18 front and see what differences there are if any.
Old 03-03-2012, 08:56 AM
stevethe6th
Originally Posted by mcar00
315's can be used on the front of the C6 Z06 given the proper wheel but I think your issue is not one of tire size but wheel offsets. I would try to compare the dimensions and offsets of the C5 Z06 rear to a CCW 13X18 rear and see what differences there are if any.
Should be easy enough - I have CCWs for the street, although I believe comparison with the fronts would be more useful. Bob at house of Wheels assured me the C5Z rears work on the front of the C6Z. I will post results.
Thanks to all for the feedback.
To Anyone Running 315's on Front of C6Z?
Quick Reply: Anyone Running 315's on Front of C6Z?
