What Belts Do You Run? (C5 Z06)
Old 03-09-2012, 05:48 PM
Bad Karma
Bad Karma's Avatar
Default What Belts Do You Run? (C5 Z06)
I've used Gatorbacks in the past and always been happy with them.
I purchased a set for the Z and the AC belt was too small and wouldn't even fit, the serpentine belt fit but the tensioner was sitting farther than it was before I removed the old stretched out belt. I don't feel comfortable using those sizes since I plan on getting out on the track this year.
Any recommendations?
Old 03-09-2012, 05:52 PM
froggy47
froggy47's Avatar
Stock.
Quick Reply: What Belts Do You Run? (C5 Z06)
