relay on pass. side floor? in the way of hardbar rail
hey guys - what is the relay on the floor on the passenger side? its in the way of where I have to put the hardbar rails.
i unplugged it and got traction control error.
can i relocate it somewhere? Besides having 2 small bolts, i think its glued on the floor too. I don't want to pry it up before knowing what to do with it after i pull it up and making sure i won't damage it.
thanks!
thanks!
Lateral Accelerometer: The lateral acceleration sensor measures the centrifugal force created in a turn. The data it provides is weighed against all of the other inputs and is used to calculate whether or not the car's limits are being exceeded for the speed and traction conditions that exist. This sensor is located beneath the passenger seat.
ok - can i remove/relocate it?
If your car is a C5Z you will need it for the traction control. I pried mine up and mounted it on top of the Hardbar rail. I drilled two holes in the bottom of the rail, countersunk and used bolts and nuts to attach
got it. thanks guys.
