made my own splitter
Old 03-11-2012, 05:08 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default made my own splitter
So after hunting all over for what i wanted, i was tired of either the service of places, or the cost of sum. Because really..a splitter is a wear and tear item on a car that is used on the street. I found a place that sells .250 abs plastic sheets and went to work
Old 03-11-2012, 05:12 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Man, you are going to have a ton of front down force. You may need to add support to the front facia.
Jim
Old 03-11-2012, 05:22 PM
VGLNTE1
VGLNTE1's Avatar
The splitter is bolted to the bumper, but also is mounted to the frame as well
Old 03-11-2012, 06:09 PM
eogel
eogel's Avatar
What is the piece between the splitter and the bumper?
Thanks,
Ed
Old 03-11-2012, 06:11 PM
VGLNTE1
VGLNTE1's Avatar
The aci front splitter.
Old 03-11-2012, 06:13 PM
VGLNTE1
VGLNTE1's Avatar
I did a test just to 130mph and man i could really see a difference. The front it not loose anymore due to the wing. In fact i could fell the rear get loose over small hills. Now i can actually tune thr wing to balance it out. I love this crap
Old 03-11-2012, 07:30 PM
mountainbiker2
mountainbiker2's Avatar
Looks great. Can you shoot more pictures? I want to see how you mounted the undertray under the car. Did you block the sides of the radiator? How did you mount the turn buckles? I want to make one also, but I need more ideas.
thanks,
Steve A.
Old 03-11-2012, 10:01 PM
Han Solo
Han Solo's Avatar
Mind sharing the source and cost of materials? How much does that piece weigh?
Old 03-11-2012, 10:29 PM
VGLNTE1
VGLNTE1's Avatar
I didnt want to pay the huge amount for shipping. You can abs plastic online all over, but shipping is insane. I found a local place that sold .250 thick 4x8 sheets for 120$ the splitter was made from 6'x3'. The piece weighs maybe 3-4 lbs if that. Super light durable stuff.
Old 03-11-2012, 10:38 PM
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
If I were you, I'd make a cut out template to include the holes and hook some brothers up. That is an awesome creation and I been wanting to do a splitter for quite some time, but they are either too short, too tall, too weird, etc. You concept is awesome.
I also understand the need for a rear wing to balance out the down-force up front as well. Spoke with another forum member on the phone a few times reference his nice set up as well.
Great concept! And it looks awesome!!!
For once, I come to find a useful thread started by you that isn't a political rant against that bozo in the White House. Hahahaha (Most of which, I agree with too)
Thanks for sharing
ErnieN85 (06-03-2016)
Old 03-11-2012, 11:27 PM
froggy47
froggy47's Avatar
Nicest diy piece I have seen in months.
Old 03-12-2012, 12:15 AM
GettReal
GettReal's Avatar
I have an aci splitter kicking around collecting dust, might be a good project do you have a better pic of the inside of your wheel well that shows how you mounted that vertical piece to the new splitter and also to the wheel well?? Great job
Old 03-12-2012, 10:12 AM
VGLNTE1
VGLNTE1's Avatar
Thank you guys. Been pondering this project and doing alot of research for a long while now. I will get some more pics tonight or tomorrow. The bad thing with duplicating my splitter to fit another car is you would need an aci or one like it to bolt to. All i did was mount it to the rad frame section, or bumper scrape gaurds, then drilled through the splitter and aci once it was on to make sure the holes mounted perfect. I took the bumper off and set it on the splitter to get the perfect fit. I had to do alot of cutting once it was on to match it up perfect.
Old 03-12-2012, 11:37 AM
Han Solo
Han Solo's Avatar
Found another possibility for material.
http://www.grainger.com/Grainger/Sheet-Stock-1ZBB3
Grainger says shipping weight on a 4x8 sheet of 1/4" ABS is 44 lbs.
http://www.grainger.com/Grainger/Sheet-Stock-1ZBU5
Old 03-12-2012, 11:38 AM
VGLNTE1
VGLNTE1's Avatar
I really think it needs to be at least .250 thick. i think 1/8" may be way to thin for rigidity
Old 03-12-2012, 11:45 AM
travisnd
travisnd's Avatar
That turned out great. I had the sme idea for if I ever go full out ST2 and can do aero. Get the ACI waxer front chin spoiler cheap and add ABS or alumalite to make it a proper splitter.
Old 03-12-2012, 12:23 PM
1991Z07
1991Z07's Avatar
Any place that sells plastics should be able to get you what you need...
You could even do it in 1/4" thick Delrin if you wanted...
Excellent work...
To made my own splitter
Old 03-12-2012, 12:46 PM
Han Solo
Han Solo's Avatar
Oops! Thought I had clicked on the 1/4" size.
They want a little more for that and the shipping weight shows at 40 lbs.
http://www.grainger.com/Grainger/Sheet-Stock-1ZBB5
Old 03-12-2012, 12:52 PM
RDnomorecobra
RDnomorecobra's Avatar
you get enough air to the radiator? it's a front breather now?
Old 03-12-2012, 12:56 PM
VGLNTE1
VGLNTE1's Avatar
no I dont. The front bumper still needs cut. Few things left to do
Quick Reply: made my own splitter
