R-D Racing Cross-Bar for Convertible...
Old 03-16-2012, 08:29 AM
94ZR1#444
94ZR1#444's Avatar
Default R-D Racing Cross-Bar / Harness Bar for Convertible...
Not sure how much these were new as I can't find the R-Dracing.com website anymore. I believe these were around $300+ new. This one is like new. This is for a C4 only that I know of. It may fit other models but I don't have any info on any other model than the C4.
Fits between the two seat belt anchors. Installs in minutes. Stiffens chassis. Can be used for safety harness mounting. Has two threaded holes in the middle of the bar I assume for a camera or fire extinghisher mount.
I'd like to get $150 OBO plus shipping.
Last edited by 94ZR1#444; 04-28-2012 at 06:53 AM. Reason: Spelling correction. Information update.
Old 03-24-2012, 06:29 PM
TorchTarga94
TorchTarga94's Avatar
Will this also fit the coupe?
Old 03-25-2012, 10:00 PM
NASCAR314
NASCAR314's Avatar
NO! verts only. Will not work on a cpe.
I ran one for years on my convertible and it really stiffened it up. You still have full use of the retracting top as well.
Do you have the two "bolts" that go into the seat belt anchors? I can't remember if you used the original bolts, or if it had custom bolts???
Old 03-25-2012, 10:03 PM
TorchTarga94
Thanks for the info!
Old 03-26-2012, 04:36 AM
94ZR1#444
94ZR1#444's Avatar
It uses the same bolt for the seat belt anchors, no special bolts.
Old 04-28-2012, 03:48 AM
bbromiley
1st Gear
bbromiley's Avatar
If this is still available and for the c6, I'm very interested.
Old 05-03-2012, 09:51 PM
swil42
1st Gear
swil42's Avatar
I'm interested in your cross bar for $150.00 if it fits a 96 convertible?
Old 05-04-2012, 06:21 AM
94ZR1#444
94ZR1#444's Avatar
This will fit a 1996 C4 convertible. IM me with your contact info.
To R-D Racing Cross-Bar for Convertible...
Quick Reply: R-D Racing Cross-Bar for Convertible...
