Front bearing going bad - repl both?
Old 03-17-2012, 12:11 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Front bearing going bad - repl both?
Between the noise and the slight play in the 12 and 6 shake it appears my d/s front bearing is going. Passenger side seems fine for now. Should I go ahead and repl both? Do they generally go bad at the same time?
Old 03-17-2012, 07:40 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
For the time it takes and the whole "Since I already have the car in the air", I would change both just for peace of mind.
I had one go bad and I bought both and I think we did both in my buddy's garage without a lift in 90 minutes from taking wheels off to putting them back on. The upper bolts are a piece of cake, but the lower bolt is blocked by the ball joint, so you need to detach it. That takes the most time.
Hope that helps some.
Old 03-17-2012, 08:52 AM
CHJ In Virginia
CHJ In Virginia's Avatar
IMHO- I would replace both bearings while you are doing the job. Since you are tracking the car spend the extra $ and get the SKF race bearings. Piece of mind that you are running the best available equipment is priceless.
Old 03-17-2012, 04:13 PM
dbratten
dbratten's Avatar
Not to say the sky is falling but don't assume both fronts will wear out together. After several years of autox and track days on Kumho 710s I first lost a left rear (which I replaced at the track with a Delco) and then a week later a left front went out. Actually, they both sheared off. Apparently, I was taking more right turns than left. I decided then to replace all four with SKFs and keep the new Delco as a spare.
Old 03-17-2012, 04:57 PM
1991Z07
1991Z07's Avatar
I replace ALL my bearings when one goes bad. They will eventually all fail close to each other...and while I have it in the air, I may as well do them.
It hits the pocket...but at least I know they are ALL good...
Old 03-17-2012, 06:15 PM
Olitho
Olitho's Avatar
I agree. Once one fails I don't think the others are far behind from my experience. The fronts tend to go first in my experience.
Old 03-17-2012, 08:22 PM
sperkins
sperkins's Avatar
Maybe I'm just crazy, but I only replace them when they're obviously bad. I've never had two go bad at the same time.
4 SKF's is well over a grand.
Old 03-17-2012, 10:10 PM
1991Z07
1991Z07's Avatar
I tried that once or twice...
I had the second go bad after 2-3 months, the third a month or so later...etc.
Just get it over with...I keep the ones NOT so bad and have them in case of emergency for track changes. MUCH better to replace them all at the same time.
Old 03-18-2012, 09:51 AM
Aardwolf
Aardwolf's Avatar
I don't replace both especially the front which is simple to change. I have not had both fronts go bad at the same time. If you have enough money to waste a part with service life left in it then change both. Give the part to someone else to run. I have put on several used bearings and gotten the rest of the moneys worth out of them!
Old 03-18-2012, 10:49 AM
drivinhard
drivinhard's Avatar
I have simply replaced my failing OEM ones one at a time, as they fail, with SKF race units. There are no issues with this. My OEM ones lasted anywhere from 1 yr to almost 3 year.
There is no common labor to doing 1 corner at a time, so it's not any more work to mess with another corner down the road.
Old 03-18-2012, 02:17 PM
froggy47
froggy47's Avatar
I haven't had to do this on my c5z yet, on the c4 I did the whole axle at a time, but not the other end. These are too expensive to replace a good part unless you are made of $$$.
On the c5z I will prob do each corner at a time. Like drivinhard says, NO common labor.
Old 03-18-2012, 06:01 PM
timd38
timd38's Avatar
I replaced all 4 with the SKF bearings when I installed my brakes since it was already apart.
You can not use OE rears on front becasue the bearing on the rear is secured buy the axle nut. The SKF performance bearings have them rolled, so you can use them on the front or back.
Old 03-18-2012, 10:07 PM
waddisme
waddisme's Avatar
Don't see anything gained by doing the other until it is ready. May try to get a volume discount on two then at least have it ready.
Old 03-19-2012, 11:55 PM
waddisme
waddisme's Avatar
Do you guys leave stock studs in or repl with ARP while it is out?
Old 03-20-2012, 12:24 AM
Olitho
Olitho's Avatar
I might take this approach if I was doing track days or autocross, but I am not going to drive 750 miles one way to a track like Miller or even 200 mile to WSIR and have a hub fail in a 35 minute national race. When one fails I am going to replace them all. As it is now, I preemptively replace them all about every 18 months anyway.
Old 03-20-2012, 12:26 AM
Olitho
Olitho's Avatar
Originally Posted by waddisme
do you guys leave stock studs in or repl with arp while it is out?
arp
Old 03-20-2012, 02:23 AM
jimtway
jimtway's Avatar
Whats the common failure mode of the OEM hubs? and the SKF hubs?
To Front bearing going bad - repl both?
Old 03-20-2012, 06:00 AM
larryfs
larryfs's Avatar
The left side fails much more often.
unless you visit a race track that runs counter clockwise.
Old 03-20-2012, 08:46 AM
varkwso
varkwso's Avatar
I replace as they fail. I keep stock studs.
Old 03-20-2012, 12:28 PM
froggy47
froggy47's Avatar
arp
Quick Reply: Front bearing going bad - repl both?
