Question about removing seat belts for harnesses.
I just purchased a RSD Roll Bar and Corbeau A4 seats in my C5 hardtop. I want to eliminate the factory seat belts to use just the harnesses that I purchased. I was wondering if anyone knew of a blank pillar to fill in where the seat belt would sit on the floors? I don't want to hack up the stock ones just in case I want to put them back to stock ever. Any help???
Received 8,926 Likes
Why not see if any of the Corvette Used Parts dealers have a set of B Pillar moldings and just cut them to eliminate the section you are talking about. It is a race car so it doesn't really need to look all that pretty. Pretty usually slows a car down.
Bill
Bill
Thanks for the info, I think I may try that idea!
Will the car still be driven on the street? If so, you could very well get pulled over for no seat belts. Aftermarket 5 and 6 point harness systems are not DOT-approved and I think that every state requires the use of OEM belts on the street.
And using a harness on the street is a PITA especially if you are in and out of the car a number of times per day.
Most harness manufacturers will provide attachment pieces that will allow the continued use of the OEM belts. When I bought my G-Force harnesses, they came with slightly longer bolts for mounting both the OEM belts and the lap harness belts at the factory locations. Same with the shoulder belt mounting bolts. The roll bar should not interfere with the OEM belt mounting points.
Here are some marked pictures of what I think you are trying to cut back.
You probably know you can remove the lower panel separately from the quarter panel piece where the shoulder belt mount is located.
There may be a way to cut the lower panel diagonally so it bends inward toward the frame rail and can be fastened to the frame rail when the retractor is removed. Would still take up room on the B pillar but would give more room on the floor and just above it. That panel attaches to the B pillar with pins that are glued to the back side of the panel so you would have to remove those pins, shorten them some way and then reglue them.
Bill
I take it you are trying to get a little more room along the B Pillars. The stock lap belt retractor down by the floor uses a couple of inches of floor space. I know when I put my race seats in my C5Z I was limited to a 17 inch wide seat since the retractor pushed out from the frame right at the rear of the seat mounting rails and severely limited seat mounting options.
Bill
Bill
