C5 Transmission Fluid & PS Fluid Change
I have a 2000 C5 and do autoxs and a couple of track day events/year. Last summer flushed out my PS system w/NAPA PS fluid and replaced a PS pump and plastic pulley w/metal Z06 pulley. There were still some tight spots in the steering in the turns at Summit Point main track. I flushed the PS system and added about a half squeeze bottle ( maybe 4-6oz) of Lucas Oil PS conditioner/stop leak. The tightness went away. I would like to run some high temp PS fluid. Any suggestions?
Regarding PS rack rebuild: Am I living on borrowed time with the Lucas Oil product? Just bite the bullet and send rack to Turn-One for a rebuild?
Would also like to change transmission fluid. Any suggestions from anyone who runs an non-factory or non-GM fluid? Is there a high temp trans fluid too?
Also,
I replaced the factory front rubber bushings with Pfadt poly two years ago. Should these be pulled out a relubed every now and then?
Also,
