Seat Stud Removal
Old 03-23-2012, 08:54 PM
YYZ06
YYZ06's Avatar
Default Seat Stud Removal
I've done a couple searches and have seen threads with folks going to remove the studs but haven't seen one where someone has actually done it.
I installed some Corbeau A4 seats and got the supports on for the BK harness bar on with good thread engagement. However, I'm concerned about having enough thread engagement with the Vetteworks sub belt bar. I was thinking I'd be better off changing out the studs for Grade 8 bolts that are a bit longer than the stock studs.
I've heard of grinding off the bottom of the stud and pushing them up through the floor but was wondering why can't the be pounded back through the bottom? They seem to be bonded in place with some type of plastic or epoxy.
What is the best way to remove the studs on a C5 to use bolts instead?
Old 03-23-2012, 09:41 PM
Falcon
Falcon's Avatar
Grind the head off the bolt. You'll have to get under the car to do that. Once the head is off, you can push it out from the top.
Old 03-23-2012, 11:09 PM
sperkins
sperkins's Avatar
I didn't have access to a grinder so I hammered them out from inside the car. I put a socket on a floor jack and put it around the bolt head from under the car. Make sense?
BTW - those bolt heads are only tack welded in three spots around the perimeter. It doesn't take much to pop them out. You'll be surprised at how thin the flat bar is that they're welded to. I would pick up some 1/8" flat bar, drill holes to match the floor and run your new bolts through them as an added safety measure.
Here is how I did it on my old car.
The following 3 users liked this post by sperkins:
Bossdog (01-01-2017), G_Loc (12-18-2021), smitty2919 (03-12-2021)
Old 03-23-2012, 11:44 PM
YYZ06
YYZ06's Avatar
Excellent idea. Thanks!
Old 03-24-2012, 08:52 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I thought you could just bang them out with a hammer, from the inside. I don't remember needing to support them as sperkins said, but it sounds like a good idea.
Old 03-24-2012, 09:38 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
B
f
h
Old 03-24-2012, 11:28 AM
jlutherva
jlutherva's Avatar
No, no, no!
just thread the nut onto the bolt from the top and wiggle it back and forth with vise grips. They come right out.
Jim
Old 03-24-2012, 04:14 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Sometimes that works, sometimes the weld is better than others and the cross bracket tears. Anything that can be a PITA, eventually will.
Old 03-24-2012, 04:29 PM
Falcon
Falcon's Avatar
Yep, I tried all those methods mentioned in this thread and managed to completely screw up the bolt from the top, but it still wouldn't let go. I used a BFH and even a GBFH's, but it wouldn't punch through.
That's when I broke out the grinder from the bottom, and it was easy.
Old 03-24-2012, 04:39 PM
fatbillybob
fatbillybob's Avatar
If you want more security I would have added the 1/8" bar all the way to the tunnel and the outter sill box and tack welded it. If you end inside those points on the thin GM bar how is that stronger? All you do is move the weakest failure point to the end of the new 1/8" bar. I'm not an engineer so maybe I'm wrong.
Old 03-24-2012, 04:41 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Scott needs ballast so all of his brackets are 1/2" steel.
Old 03-24-2012, 05:11 PM
sperkins
sperkins's Avatar
Have you ever seen how thin that OEM cross bar is? By putting the bar there you're spreadig the load from two 1/2" holes to the entire cross section.
Old 04-01-2012, 10:19 PM
YYZ06
YYZ06's Avatar
I ended up using sperkins method. I had previously installed some Corbeau seats and had the rear bolts and B-K harness bar supports installed. I didn't want to take that apart to remove the seat. I used a cold chisel and a 3 1/2 pound hammer and supported the bottom using a jack and 24 mm deep socket. It went pretty smooth after I got the hang of it. The method was, pound the stud from the top until there is some separation of the stud head and the brace then use the cold chisel to break the welds holding the stud.
After removing the first one, I decided to try the grind off the bottom method on the second one. I felt that I'd be older and grayer than I already am before grinding it all the way down and went back to the hammer and chisel. If the seat was out, it would have been really smooth because I could have pounded straight down. I had to work around the seat bracket but it was still much faster than grinding the bottoms off.
I also reinforced the area with 1/8" Steel. The spot welds tear the metal a bit so I like the idea of spreading the load a little more.
Here are the tools:
The bolt with the three spot welds (as previously mentioned):
The brace after the bolt is removed:
The finished product:
Thanks for the help!
Old 04-02-2012, 07:46 PM
sperkins
sperkins's Avatar
Old 05-24-2012, 04:03 PM
moespeeds
moespeeds's Avatar
Just curious, you guys that are pulling the studs, what size bolts you putting back in, Grade 8, 1/2"?
Old 12-21-2012, 01:38 PM
YYZ06
YYZ06's Avatar
I used Grade 8 - 3/8 x 2" coarse thread flange bolts. I'd say one could get by with 1.5". I have the Corbeau seat brackets and Veteworks sub-belt bracket.
Pix
Old 01-01-2017, 10:36 AM
Bossdog
Bossdog's Avatar
Thanks for all the great info. I'm getting ready to add the Corbeau A4's to my C5Z along with the sub belt mount. I'll use all the great info here.
To Seat Stud Removal
Old 01-06-2017, 02:03 PM
waddisme
waddisme's Avatar
Wow! Talk about a blast from the past. Where you been man? I was thinking the other day about all the guys who used to rule this forum. You, An U Egl, Varkwso, brkntxn, cobra4b, jason?, 9?Jersey are some of the names. Never see them on here any more. I guess they've gone to Miata forum?
Welcome back.
Old 01-06-2017, 02:52 PM
Scooter70
Scooter70's Avatar
Check the post dates. Someone brought a thread back from the depths of the archives.
Old 01-06-2017, 03:38 PM
waddisme
waddisme's Avatar
Quick Reply: Seat Stud Removal
