GT Racing Tires is ready for summer
Old 03-26-2012, 05:34 PM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
Default GT Racing Tires is ready for summer
Are you ready for summer? At GT Racing Tires we are. Most tires are $100.00 each plus actual shipping.
Call Todd at 414-350-6303 or Greg at 414-640-7218
Most tires have only one heat cycle with 75% or better rubber remaining.
If we won't run a tire on our cars we won't sell it!
CONTINENTAL
SLICK 225/45/15
SLICK 225/45/17
SLICK 245/45/17
SLICK 275/40/17
SLICK 265/645/18
SLICK 275/35/18
SLICK 285/645/18
SLICK 305/350/18
SLICK 305/660/18
SLICK 325/680/18
SLICK 325/710/18
SLICK 325/710/19
RAIN 285/645/18
PIRELLI
SLICK D2 245/620/17
SLICK D2 285/645/ZR18
SLICK D2 305/675/R18
SLICK D2 305/685/R18
SLICK D2 315/675/R18
SLICK D2 325/650/18
WET 305/675/18
TOYO
R888 235/40/R17
R888 305/35/R18
R888 335/30/R18
HOOSIER
SLICK 225/45/R17
SLICK 245/45/R17
SLICK 275/40/17
SLICK 275/35/R18
SLICK 265/645/R18 R80
SLICK 320/650/18 R100
DOT 215/60/15 R6
DOT 225/45/15 R6
DOT 225/45/R16 R6
DOT 225/50/R16 R6
DOT 245/45/R16 R6
DOT 225/45/R17 R6
DOT 245/40/R17 R6
DOT 245/45/R17 R6
DOT 295/35/17 R6
DOT 245/35/R18 R6
DOT 255/35/R18 A6
DOT 335/30/R18 A6
WET 245/45/17
KUMO
DOT 225/50/R16 V710
DOT 245/45/R16 V710
DOT 245/45/R17 V710
DOT 275/40/R17 V710
MICHLEIN
DOT 275/35/18 D.C. 4100
DOT 335/30/18 D.C. 1501
PILOT SPORTS
DOT 295/35/R18
YOKOHAMA
SLICK 240/640/R18
SLICK 280/680/R18
Old 04-02-2012, 12:22 AM
GettReal
GettReal's Avatar
Hey Todd, I got the Conti's all mounted up.. thanks. Question for you on these... What pressures are good starting points in cooler weather (60 degrees) What cars did these come off of?
Also, do you know what run better in cooler weather, these Conti's or the Grand Am Pirelli slicks I got from you? I'm trying to decide what I want to run at the Glen end of April, and I think it might be cool.
Old 04-02-2012, 07:31 AM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
PM sent.
Old 04-02-2012, 01:52 PM
GT Racing Tires
Supporting Vendor
Starting pressure points depend on the weather. We found that 28-30 hot is ideal. If it's cold run the Conti's. The Pirelli's will be a challenge to get heat in if it's below 55. Depending on what you bought they likely came off a GT car.
Old 04-02-2012, 03:41 PM
TGiuliante
TGiuliante's Avatar
Default tire for C6 Z
Do you have any pilot sport equivalents in stock 2007 c6 Z06 sizes - 18" front, 19'Rear? tires like Nitto Ra1, Michelen pilots, toyo RA1's etc. Looking for a street tire that may see occasional track duty - or if it rains and i cannot run my Hoosiers I and run my street tires.
let me know
Old 04-02-2012, 06:22 PM
GT Racing Tires
Supporting Vendor
let me know
Sorry the only tires we have in 19" are the Continental slicks.
Old 04-04-2012, 11:43 AM
sebdavid
sebdavid's Avatar
I'll post here, if you want you can respond via email at sebdavid at hotmail dot com or directly here, could be useful to others:
I'll soon be running stock C5Z 18" rear wheels at all corners on my C5Z. I'm looking for tires that would fit that arrangement, ideally 295 in front and 305 in the back. What do you suggest? I don't seem to find a suitable match in your above list...
I'm running HPDEs as an instructor, looking for inexpensive durable tires mainly. If they'll give me good grip that's great too! I'll be using street tires on the stock 17" all around when it rains and to get to the track.
Thanks for the help!
Old 04-04-2012, 12:11 PM
Cory M
6th Gear
Cory M's Avatar
Are your Yokohama's the Patron series tires?
Old 04-04-2012, 12:29 PM
RDnomorecobra
RDnomorecobra's Avatar
my $0.02 ... you can use the 295 Michelins or the 305/35 R888's on all 4.
Old 04-04-2012, 12:33 PM
sebdavid
sebdavid's Avatar
Thanks for your input.
The 295 Michelins would work, but I'd like to go as wide as possible in the back. Also, not clear if those are Power Sport Cup (R compound) or some other Power Sport model (street tires).
305 may be too wide in front with brake ducts, I've never actually tried anything wider than 275, 295 seems like a conservative first-time try, that's why I was going for that size.
Old 04-04-2012, 12:42 PM
ninety4formula
ninety4formula's Avatar
pm sent
Old 04-05-2012, 08:34 PM
GettReal
GettReal's Avatar
Seb, I have a few sets of track wheels and the one set of 10.5 x18 I ran a square set of 300/18's and right now they have a 305 square set up with the Pirelli race slicks. My other set is the Conti slicks with 305s in the rear and 285s in the front. I haven't had any issues so far with any of my set ups except at full lock. I have -2degrees of camber up front, coil overs and have brake ducts
Old 04-05-2012, 08:39 PM
sebdavid
sebdavid's Avatar
Good to know, thanks for the input.
Before actually buying tires, I'll try to put my other Falken Azenis 315s on the 18" in front, see if I have an issue with rubbing anywhere. If I do, then I'll stay away from anything above 295 as the Falken are not particularly wide tires.
Old 04-24-2012, 07:57 AM
72Vega
72Vega's Avatar
PM sent
Old 05-02-2012, 09:10 PM
MiggsC6r
6th Gear
MiggsC6r's Avatar
I need to get a set of track rims , I need to run 18s in the rear so I have better options for track tires. Anyone know of any brands , or places that wont cost me a fortune ?
Old 05-07-2012, 03:14 PM
C6Z51GUY
Cruising
C6Z51GUY's Avatar
Hey guys I was wondering if anyone could help me out on a few quick questions I have what is the widest tires I can put on a stock c6 corvette with a z51 package and if anyone can recommend some street slicks for me. Thanks guys
To GT Racing Tires is ready for summer
Quick Reply: GT Racing Tires is ready for summer
