Variation of Power Loss Through Drive Train/Differentials?
Does anyone know what the approximate power train horsepower loss is through a stock differential vs. Quaife vs. OS Giken and other diffs. Is there much difference?
Depends on mass of the diff. Your frictional losses will all be in the gear set/trans/drive line, not the diff (assuming straight line, no slippage). I'd imagine the differences would be slight as the diff itself is fairly small diameter compared to, say, a wheel/tire combo.
Yeah, I figure so, too, but I am wondering if the torson style gear diff of the Quaife I have sucks out more power that the stock or OS Giken clutch type.
My Quaife itself is rather heavy with all the gears inside. It sure does get hot, too.
Oli
The Quaife should get hot when "working" (in turns). Otherwise I don't think it would eat more power since the spyder gears don't move when the wheels are at the same speed.
I know, I'm just being pedantic. Though i admit to now being curious about how much slipping the diffs do on the "straights" and how much power loss that amounts to.
Would a locker (wiessman or detroit) be different? Or how about going Mark Donohue style and running a spool?
Rule of thumb used to be 20 percent plus or minus. For example a stock LT1 Corvette at 300HP will put down between 247 and 257 on a dyno by the post information I have. Thats not 20 percent but you get the picture.
He's asking about loss from the differential unit itself, not from the entire driveline.
