Splitter angle?
Old 04-03-2012, 04:09 PM
mountainbiker2
mountainbiker2's Avatar
Default Splitter angle?
What angle do we put the under tray? Can you give me a reason for your answer?
thanks,
Steve A.
Old 04-03-2012, 04:20 PM
Falcon
Falcon's Avatar
thanks,
Steve A.
The front of the splitter should be lower than the rear of it, otherwise you'll be creating lift.
Old 04-03-2012, 05:25 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
stick your hand out the window at 70mph...the angle you start to feel the wind push it down, use that one. lol
Old 04-03-2012, 07:46 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
thanks,
Steve A.
You are trying to create a vacuum or negative pressure under the car. When there is a negative pressure air travels faster creating lower pressure hence more down-force or negative pressure. That is why a real diffuser tries to straighten the air and make it exit faster. That is why you want a flat as possible bottom on a car or even fully plate it. It creates less turbulence for faster exit. Just think weather if your are in a low pressure zone it tends to be windy as air travels in to fill the gap.
Old 04-03-2012, 09:40 PM
Jaymz
Jaymz's Avatar
With my setup I can adjust the rake on the splitter. I try to get 2 to 3 degrees down. I measure this with a digital level at the track with the car sitting as level as I can get it.
Old 04-03-2012, 11:54 PM
mountainbiker2
How wide is your under tray? Mine is 30". 2-3 degree of rake would be around 1" to 1.5" lower in the front. I don't know if my figure is right, but is yours that steep?
thanks,
Old 04-04-2012, 07:15 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think as long as it is level, or slightly lower in the front, it is effective. Usually you add venturis to the undertray instead of cambering the entire splitter.
Old 04-04-2012, 08:57 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Not this low:
http://www.youtube.com/watch?v=_fm_CgLaCQ4
Old 04-04-2012, 10:31 AM
BERETTA
BERETTA's Avatar
Thats gotta be $500.00 worth of sod at Barber...
Old 04-04-2012, 10:48 AM
el es tu
el es tu's Avatar
That was an interesting race. What made the rx8 driver cross the track like that?
Old 04-04-2012, 11:17 AM
Falcon
Falcon's Avatar
If I remember correctly, the RX8 had spun off track right, and thought he was in the clear when he pulled back on track. The DP car came around that turn pretty quickly and had a windshield of RX8 and took evasive action.
Old 04-04-2012, 11:32 AM
redtopz
redtopz's Avatar
That rx8 driver was really bad. First he spins for no reason, then he pulls 90 degrees across the track with multiple cars flying towards him. He must have a lot of cash, because he didn't get there on talent alone...
Old 04-04-2012, 12:24 PM
TLGunman
TLGunman's Avatar
Originally Posted by Jason
and that is how tough your splitter should be!
Old 04-04-2012, 05:52 PM
Falcon
Falcon's Avatar
I just measured my undertray and the angle is 3*.
Old 04-04-2012, 06:41 PM
John Shiels
To Splitter angle?
Quick Reply: Splitter angle?
