did you guys know about this? trans temp gauge on dic
Old 04-03-2012, 10:38 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default did you guys know about this? trans temp gauge on dic
http://www.hptuners.com/forum/showthread.php?t=33223
Anyone by chance have pics if you have done it? Very interested
Old 04-03-2012, 11:45 PM
Z06trackman
Z06trackman's Avatar
This is an outstanding piece of info, and just what I am looking for. Thanks!
Old 04-04-2012, 06:34 AM
VGLNTE1
VGLNTE1's Avatar
And it looks like mn6 does not have one :-/
Old 04-04-2012, 10:38 AM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
It will flash if it gets hot. Saw it once a few years back while running a 30 minute session at a road course. I now have a tranny cooler and have never seen it since (03 C5Z).
Old 04-04-2012, 11:13 AM
PA Z06
PA Z06's Avatar
Great find, I would be interested to hear if anyone here has tried it
Old 04-04-2012, 11:21 AM
VGLNTE1
VGLNTE1's Avatar
yes, but this shows how to make it an actual temp gauge
Old 04-04-2012, 12:30 PM
froggy47
froggy47's Avatar
My mech wanted $300. to wire mine up. Pass. Maybe I'll do it myself, but I would rather just have a cooler tran. temp.
Old 04-04-2012, 03:18 PM
TorontoC6
TorontoC6's Avatar
I know about it because I have the auto. When I track, I put the DIC on tranny temp and watch it. I cool off a little when I hit 235 but have seen as high as 248 during some chase downs. If you get temp warning on the auto, it will shut down your gear shifts. I change the fluid and filter regularly. I continue to add tranny heating (through the radiator) and cooling to manage temps - too much cooling is a bad thing. Installing a dual core Dewitts with twin oil and tranny coolers next week before Watkins Glen. With good tuning, the automatic can be very rewarding using paddle shifting. Also, no double clutching required. Good for us lazy old guys.
Old 04-04-2012, 04:19 PM
SouthernSon
Have you talked with folks running water to fluid and air to fluid cooling? Even here in the south the preferred method seems to be air to fluid. Up in the northern climes I would think you might rather give your engine cooling the whole radiator and let the air cooling do the rest. ...just sayin'.....
Old 04-04-2012, 04:53 PM
travisnd
travisnd's Avatar
The Z06's MN12 has the trans temp gauge in the fill plug. However, you can't pull up the reading on the DIC unless you overheat it. Pretty stupid IMO. If you get it to 276 it'll flash trans overtemp warning and show you the temp. Then if you don't hit anything you can keep the trans temp up and watch the temp. Not sure why they didn't just make it accessible all the time via the DIC.
Old 04-04-2012, 05:25 PM
Git Er Dun
Git Er Dun's Avatar
^That's what this does. It tricks the computer/DIC into being able to display it all the time.
Old 04-04-2012, 07:54 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Unless you figured some way to plug it into the transmission in addition to the cooler line you will never see a temp warning since the sensor isn't on the car. When I installed tranny coolers in my two C5s the outlet side of the cooler goes into the fill hole of the transmission which is exactly the place the sensor goes.
Bill
Old 04-04-2012, 08:32 PM
MySR71
MySR71's Avatar
Bill
I'm not sure what cooler kit Southern Son is using, but the DRM kit uses a T-fitting with one side going to transmission's fill port, one side the return line from the cooler, with the third port for stock trans temp sensor. Given the flow rate of their kit, the sensor is still likely submerged in oil. It will measure the oil temp after the cooler.
EDIT: Here, I just found this photo.
If you want to also measure the temp before the cooler, that can be done too of course. It requires extra fittings, sensor, and a gauge/data system.
Old 04-05-2012, 04:39 PM
SouthernSon
Bill
Not sure how it is plumbed. The fuel pump for transporting the tranny fluid is in the RR quarter panel and the little independent radiator is in front of engine radiator. If the sensor is no longer in the loop it is probably OK now since I have run many miles on track since with no problems. But, as stated earlier, it didn't seem to take too much to light up the warning before extra cooler installed.
Old 04-05-2012, 04:58 PM
meldog21
meldog21's Avatar
I just bought a transmission from Rick at RKT. Because I knew I was going to be installing LG's trans/diff cooler kit Rick drilled and tapped a hole for the oil return line forward and higher up from the original fill/temp hole. With the separate return oil hole I was able to keep my temp sensor in the original fill hole.
This would be a pain in the you know what if you were just adding coolers, but since he was building the transmission from parts it wasn't too hard to do while the case was empty.
Dog
Oh, I should mention that Rick did a great job and provided outstanding customer service. He's available almost 24/7 if you have a problem. I had some problems during my install and called him on a Sunday night. He answered right away and we came up with a solution. I highly recommend RKT for any transmission work you might do.
Old 04-05-2012, 05:49 PM
RX-Ben
RX-Ben's Avatar
That looks precarious in the case of a cut tire.
Old 04-05-2012, 06:02 PM
MySR71
MySR71's Avatar
Normally it is behind the fender liner. You raise a good point though. I'll look into at least pointing the the sensor forward rather than rearward. That will give it some additional protection. Thanks.
Old 04-07-2012, 09:57 AM
Dirk Miller
Dirk Miller's Avatar
Bill
Bill,
Just wondering ..... Yesterday I just put in a DeWitts radiator in my '08 C6 Manual. It sure went in easily. This has the two hook ups for eng. oil cooling and tranning oil cooling. Next, I will be hooking up my tranny lines & was thinking about putting in a temp sensor as you have done. Maybe I am missing something, but doesn't it make more sense to put the sensor coming out of the tranny rather than going in? The temp that is read from the port on the top of the housing would show the cooled down temp and not the true temp.?
To did you guys know about this? trans temp gauge on dic
Quick Reply: did you guys know about this? trans temp gauge on dic
