Trans and Diff fluid
Old 04-04-2012, 08:50 AM
PushinTheLimit
PushinTheLimit's Avatar
Default Trans and Diff fluid
I'll be putting in some fresh Amsoil Trans and Diff fluids a little later this year as its about that time to do so. I put some in December 2010 for the 2011 racing season... but I still had quite a bit left over that wasn't used. Its been stored in my garage since then.
Are these fluids still ok to use or is it like brake fluid that once you break the seal, you need to use it within a short reasonable amount of time? Still looks good, but wanted some opinions before I put it in the car.
Old 04-04-2012, 10:01 AM
Falcon
Falcon's Avatar
I can't imagine it'd make any difference whether the container has been opened or not. Those fluids aren't hygroscopic like brake fluid.
I've got containers of diff, xmission fluid, and motor oil that have been opened, and I use those up before I open new ones.
Old 04-04-2012, 10:08 AM
travisnd
travisnd's Avatar
With gear oil at $15 a quart and trans fluid at $12 or thereabouts I'd sure as heck be using it. From what I've read on BITOG oils/lubes do degrade over time, but a year or two isn't a big deal.
Old 04-04-2012, 10:16 AM
RX-Ben
RX-Ben's Avatar
Use them - any moisture will boil off with no ill effects (trans and diff are vented). Only thing with a lifespan once opened is brake fluid.
Old 04-04-2012, 12:11 PM
Kubs
Kubs's Avatar
Received 1,731 Likes on 936 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
You should be perfectly fine using them.
Old 04-04-2012, 01:27 PM
PushinTheLimit
Thanks guys... now to find some time to do it.
Old 04-07-2012, 10:31 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
I don't think this is a problem and I do the same thing, particularly with the gallon jug of the Torque Drive.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
To Trans and Diff fluid
Quick Reply: Trans and Diff fluid
