Alignment question
Old 04-05-2012, 04:47 PM
TKOGTO
TKOGTO's Avatar
Default Alignment question
Got my 2010 GS back from alignment shop yesterday. Before the alignment to the Pfadt "track use w/ street tire specs" adjusted for a bit more (-) camber (F) and (R), the camber on the left side of the car was much more (-) than the right. Specifically, -1.6 (F) left vs -0.7 (F) right and -1.0 (R) left vs. -0.5 (R) right. Any ideas on what would cause the left side to get so much more (-) camber than the right?
Car is dual purpose and has been on LRP and Lightning @ NJMP, both clockwise tracks.
Old 04-05-2012, 05:32 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Curb jumping will knock it screwy. Or it was built after noon on a Friday.
Old 04-05-2012, 05:33 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Was that "before" the factory alignment, or have you ha it aligned since you got it???
Factory alignments have been known to be rather out of spec.
Bob
Old 04-05-2012, 06:03 PM
TKOGTO
TKOGTO's Avatar
Bob
Was the factory alignment.
I avoid curb jumping owning to its dual purpose usage but even if I hit one from time to time on a clockwise track, I am thinking the (-) camber on the left side would not be made more (-). that is what I don't understand.
I do have the build date somewhere...
Old 04-05-2012, 07:08 PM
froggy47
froggy47's Avatar
Stock adjusters slip.
Old 04-05-2012, 09:59 PM
sperkins
sperkins's Avatar
Yeah, but if it slipped that much you'd probably know it since the toe would be way out. Weird.
To Alignment question
Quick Reply: Alignment question
