St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by argonaut
Base C6 -yes (12.75"). Z51 C6 -no (13.4") unless you use the caliper mounting brakets from the C6. Z06 C6 - no (14")
More detailed:
Base C6 - yes (12.75").
Z51 C6 - no (13.4") unless you use the caliper mounting brackets from the Z51 C6.
Z06 C6 - no (14")
By going to either the Z51 or Z06 upgrade, you will need to upgrade to a minimum 18" front wheel. Also, in the case of the Z06 brakes, you will need to make sure your wheel spokes also clear the brakes.
