pitch black inside the exhaust tips indicating rich
Old 04-06-2012, 11:32 AM
frankgtb
frankgtb's Avatar
Default pitch black inside the exhaust tips indicating rich
my 2006 ls2 is bone stock track car and pitch black inside the exhaust tips indicating rich and maybe building up soot and carbon on the exhause valves
well running ferrari,bmw,audi etc etc produce tan/grey inside their exhaust tips
no check eng light, eng runs perfect
looked at all 4 o2s with my live data scan tool, all 4 looked busy measuring away busy
iam still running cats
both short term and longterm fuel trims were changing values quickly as well
what color is the inside of your corvette exhaust tips?
will leaning the mixture via hptuners/efi live produce same power, reliability yet cleaner exhaust ?"???
Old 04-06-2012, 11:35 AM
AU N EGL
AU N EGL's Avatar
Black That is normal
Old 04-06-2012, 12:06 PM
el es tu
el es tu's Avatar
hate to sound like captain obvious, but rather than just haphazardly changing the fuel, why dont you just get it tuned/tested on a dyno?
Old 04-06-2012, 12:07 PM
sabastian458
sabastian458's Avatar
Black is normal on the inside of the tips.
Old 04-06-2012, 12:27 PM
AU N EGL
AU N EGL's Avatar
Then drive the chit out of her.
Old 04-06-2012, 12:43 PM
froggy47
froggy47's Avatar
Every stock one runs rich (black pipe).
Old 04-06-2012, 12:49 PM
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
Black89Z51's Avatar
Factory fuel trims are rich to meet NOx (I believe) emission requirements, and for a safety margin.
Old 04-06-2012, 01:54 PM
RX-Ben
RX-Ben's Avatar
Not always the case - I had the opposite (very clean tips) on my stock C5.
Old 04-06-2012, 04:01 PM
steve J06
steve J06's Avatar
same car here, black color and very thin layer of soot inside the exhaust tips.
Old 04-06-2012, 04:34 PM
Dale1990
Dale1990's Avatar
St. Jude Donor '15
2006 LS7 here and my exhaust tips are usually black inside. From what I've seen, GM tunes these engines on the rich side for emissions and longevity - more fuel makes for a cooler combustion event.
Old 04-06-2012, 06:57 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
what color do you want burned fuel to be?
Old 04-06-2012, 10:01 PM
frankgtb
frankgtb's Avatar
tan/grey from what i know is a good combination of power and reliability
light grey/tan can indicate too lean
Old 04-06-2012, 10:23 PM
Black89Z51
Black89Z51's Avatar
How many of these other cars are you comparing to are also naturally aspirated?
Turbo exhaust temps. are significantly different and will effect exhaust color.
Check your plugs for a little more accuracy.
To pitch black inside the exhaust tips indicating rich
Quick Reply: pitch black inside the exhaust tips indicating rich
