Thoughts about radiator reposition-intelligent thoughts invited
Old 04-07-2012, 09:30 PM
Hotred94
Hotred94's Avatar
Default Thoughts about radiator reposition-intelligent thoughts invited
I have a 94 C4 and the engine compartment has always been so tight. I was thinking about removing the rad upper shroud, tilting the rad top forward to about 45 degrees, reworking the shroud, and then figuring a way for the hot air to get out, possibly through vents in the hood. That would provide a lot of room for engine work, and if vented through the hood, would provide excellent cooling and lots of down force. What are your thoughts?
Old 04-07-2012, 10:06 PM
jbondfl
Support Corvetteforum!
jbondfl's Avatar
Location: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
maybe someone in the C4 tech section would be more help??? sounds like considerable fabrication to me....
Old 04-07-2012, 11:15 PM
Hotred94
Hotred94's Avatar
Not too bad; just some sheet metal and a few other things. I am worried about going through the hood though. I have seen a few nice through-the-hood setups, just not in C4s.
Old 04-08-2012, 08:43 AM
eogel
eogel's Avatar
The only commercially made vented hood I have seen for a C4 is from Performance AFX.com. Contact Robert Finlayson, "vectorvette" on this forum. All others have been homemade variations.
Ed
To Thoughts about radiator reposition-intelligent thoughts invited
Quick Reply: Thoughts about radiator reposition-intelligent thoughts invited
