Square set up with OEM 18 inch
Old 04-11-2012, 06:28 PM
2 GTOs
2 GTOs's Avatar
St. Jude Donor '11-'12
Default Square set up with OEM 18 inch
Car is a c5z, track alignment (-2 I believe), DRM brake ducts and T1 bars. Lowered a little I want to use 4 OEM 18 inch rims and Hoosier a6 tires. What size Hoosiers are some of you using for this set up. I am thinking of starting with some 275 18 scrubs.
My other set of wheels at CCW with 315/17 and seem fine as a point of reference.
Old 04-11-2012, 07:01 PM
RX-Ben
RX-Ben's Avatar
If you don't class rules to worry about, then why not use 285s?
Somebody else may chime in about whether 315s are ok with the 10.5" wheels.
You should also put in all of the camber that you can, all around.
Old 04-11-2012, 07:50 PM
charger21
charger21's Avatar
C5 of Year Finalist (track prepared) 2019
315's on C5Z rears at all four corners seems to be a popular set-up
Old 04-13-2012, 09:53 AM
2 GTOs
2 GTOs's Avatar
Sounds like anything between 275-315 should work. I guess it will just depend on what scrubs I can find.
To Square set up with OEM 18 inch
Quick Reply: Square set up with OEM 18 inch
