got some coil overs spec'd from LG. thoughts?
So i talked to LG about my set up and what i was doing with the car. They told me to run the G2 coil with the short shock body and 700 on each corner
3200lbs with me in it
Undertray, 4" splitter
68" wing
1" lower than stock
Dba rotors, pfc01 pads, stock caliper
18s on each corner. 265, 305s
Car sees 70% street 30% track.
Thoughts?
68" wing
1" lower than stock
Thoughts?
68" wing
1" lower than stock
Thoughts?
68" wing
1" lower than stock
Thoughts?
Coming to us for advice, after LG told you what you needed, is like going to the bait shop for medical advice after the heart surgeon recommended open heart surgery.
yes I understand that, but with everyone here there is decades of experience and I do listen to advice I get in here. Im not saying LG is wrong, just curious on the thoughts is all :-)
Go with 'em! You won't be sorry!
Jim
Jim
Sounds good to me. Are they going to valve the rear shocks to match the 700 lb springs? I'm running the standard 700/600 G2 coilovers with full aero and the rear is a little soft, but it works well. I would also run larger tires such as 315 square.
68" wing
1" lower than stock
Thoughts?
68" wing
1" lower than stock
Thoughts?
Maybe this is why they told me 700 on each corner. I run a 315 track tire. 305 is on the street
