Sway bar Link question
Hey everyone,
I bought a C5 Z06 a month ago and will be doing some AutoX events and some track days later this year once I get a oil cooler on the car.
I am instaling some Pfadt Johnny O'Connell shocks and bars, when adjusting the links and doing the final bolt torquing I had to adjust one link quite a bit to get the link to line up with no bind. I did shim the bar clamps to free up the bars a bit also.
The front lined up much better.
I have built a few other cars with adjustable end links and don't recall them being that far off.
Pfadt should have provided a turn buckle.
Thoughts?
Right side
Left Side
Thoughts?
Right side
Left Side
Is the suspension at normal ride height when you are adjusting the endlinks for no bind? The picture of the right side looks to be with the suspension at full droop. Maybe that is just for the purposes of taking a picture.
The endlinks adjusted for no bind when the suspension is in full droop does not equate to no bind when the car is at isn't normal ride height.
I am using lift and lowered the car on a set of ramps to load the suspension.
I think I will drop the car to the floor and check again to make double sure.
Also make sure the surface you are doing it on is flat or the ramps are shimmed to be square and flat. Most garage floors aren't level at all, that's so they can drain well.
Should not be off that much. Something is out of alignment. Ck that mounting bushings are "equal" if that's ok, I would pull the bar off & measure it & inspect for bent/damage/etc.
Also ck your ride height is good with bar disconnected both ends.
if you are installing the links at different lengths just to get them into the holes, you are going to throw the car's balance off
you need to get the car on a totally level surface and then install the links.
to start them off, measure one of the originals, then set all of the new ones at the same length (center of balljoint to center of balljoint). Later on you can adjust individual ones to help in balancing the car out (done with scales).
good luck!
good luck!
I do not own scales or have access to a set. I could pay some one to corner weight the car, but would rather not at this time.
I will be paying for a alignment so maybe when it;s on the alignment rack I can take a look at the links again.
I just want to free up the suspension with the limited tools I have.
Don't you want to corner weight the car w/o the sway bars attached and then attach them without any preload? That's what I was attempting to do here.
This is the 4th track car I have built with adjustable end links so it's not my first time.
That's completely wrong. You'll have preload on the bar by doing it that way. That would be no different than using stock end links. He's doing the right thing by adjusting them for zero preload, but it's all a bit pointless without doing a complete setup and simulating the drivers weight as well.
I did just drop some cash on their stuff, so I can comment as I wish.
imagine a 3 inch link on the left and a 3.5 on the right because the car was at an angle...
I literally just did this mod and looking at the way you have them adjusted i would unbolt both bottom links from the control arms and make both end links meet in the middle of wear they are set now. In other words average out there pre-load and center them. My car is exactly the same and with a 1/2 drop on stock leafs i have the endlinks almost completely threaded in (about 2-3 threads from being all the way shortened). Took me about 2-3 adjustments to get them just right so the rear didn't feel like it was dragging on turn in or floaty at corner exit so keep playing with them. One things for sure though they should be almost even in adjustment as the bar will settle itself due to you not probably getting it in there perfectly even. Set them in the middle of what both sides are now and drive it with decent aggression then go back if needed. Goodluck.
If you're truly trying to eliminate preload on the bar (without doing a proper chassis setup), it doesn't if one link is threaded all the way out and the other is threaded all the way in. Zero preload is zero preload - there is no 'averaging' it out.
I'm aware of this but considering he adjusted his endlinks with the suspension preloaded on ramps his bar is probably cocked to one side slightly. If he averages them out and drives it for a day then goes back and checks the pre-load it will be much less extreme. Did you look at his pictures? Just trying to give him a tip that worked for me.
Can someone answer the following question for me?
With adjustable end links on both sides of the swaybar, the orientation of the swaybar is quite variable. Is there an optimal orientation? What I mean by this is, by adjusting the length of the end links, you are rotating the swaybar along the axis of the bushings that hold it in place. Does it matter if the end links are set to a longer length thus causing the swaybar arms to rotate more? I would imagine you want to put as little angle as possible on the spherical bearings of the end links. Is this a correct assumption?
When I switched to adjustable end links I set both end links to approximately the same length, however I was unsure if there was a more optimal setup.
I think some posters on the thread are overthinking this.
