Performance Friction 665 brake fluid
Old 04-23-2012, 06:11 PM
dc5-s
dc5-s's Avatar
Default Performance Friction 665 brake fluid
Does anyone have any experience with this stuff?
http://www.performancefriction.com/p...ake-fluid.aspx
I usually use motul RBF600 and like it, but I can get a case of this stuff for a super good deal.
Thanks!
Old 04-24-2012, 03:05 AM
rustyguns
rustyguns's Avatar
Thanks!
always compare the WET boiling point
Old 04-25-2012, 09:47 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Here is a little chart I have to compare specs:
Brand Wet Boiling Point Dry Boiling Point
Ferodo 399*F 626*F $23.95
Castrol SRF 518°F 590°F $68.95
ProSpeed 683 439*F 683*F $39.99 MTI
Motul RBF600 420°F 593°F $14.95
Motul RBF660 401*F 617*F $28.95
AP-600 410°F 572°F
ATE-Super Blue 392°F 536°F $15.99
Valvoline 333°F 513°F
Castrol LMA 311°F 446°F
Ford HD 290°F 550°F
Wilwood 570 284°F 570°F
PFC-Z rated 284°F 550°F
AP-550 284°F 550°F
PFC 660 383°F 617°F
Prices are probably not up to date.
Old 04-25-2012, 10:29 AM
BEZ06
BEZ06's Avatar
Nice chart!!
When comparing prices, make sure to look at similar quantities.
For instance, the Prospeed 683 looks like it might be cheaper than Castrol SRF.
However, the SRF comes in a liter container, and the Prospeed comes in a 1/2 liter, so the Prospeed is MUCH more expensive than anything else!!
Butt....with those #'s maybe it's worth it.
Bob
Old 04-25-2012, 04:38 PM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Originally Posted by BEZ06
Nice chart!!
For instance, the Prospeed 683 looks like it might be cheaper than Castrol SRF. However, the SRF comes in a liter container, and the Prospeed comes in a 1/2 liter, so the Prospeed is MUCH more expensive than anything else!! Butt....with those #'s maybe it's worth it. Bob
Reminder... there is a current special until April 30th...
Purchase 3 bottles of Prospeed RS683 and you get an extra bottle for FREE.
Just go to our website and select 3 qty. You open the box to find 4 bottles!
Goto this link.
http://www.mtiracing.com/Purchase/20...eed-RS683.html
Old 04-26-2012, 01:52 AM
rustyguns
rustyguns's Avatar
AP-600 410°F 572°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
PFC 660 383°F 617°F
see the wet boiling points?
wish we had a vendor that did specials on Castrol SRF !
Old 04-26-2012, 05:46 AM
RX-Ben
RX-Ben's Avatar
I read on the internet that it takes 24 months for fluid to get to its "wet" boiling point.
I have never had a problem with a low wet boiler, such as RBF600, despite lighting up the brakes on a regular basis. And I usually end up doing brake bleeds/flushes when it is raining out. Sometimes I even use a previously opened bottle.
Old 04-26-2012, 09:38 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
That list has some good choices there. But you cannot shun a brand on "wet" boiling point alone. There are some good fluids in that list.
Here is some important information about the "Wet boiling point" versus "Pedal Feel".
Very interesting indeed.
http://forums.corvetteforum.com/c6-c...post1580510469
Hope that helps!
To Performance Friction 665 brake fluid
Quick Reply: Performance Friction 665 brake fluid
