C6Z Autocross Tire Sizing info needed...
Old 04-29-2012, 11:38 PM
nmp27
nmp27's Avatar
Default C6Z Autocross Tire Sizing info needed...
Hello all...
Currently have a C6Z, has 19/20's on it, been using those for AX, I have a set of stock C6Z wheels 18/19's
Should I buy a set of A6's for the 18/19 combo? if so, what sizing would you recommend
I'll probably be hitting 6-8 events this year, just tired of babying the car around on street tires..
thanks for any input you can offer!
Thanks!
Nick
Old 04-30-2012, 12:00 AM
doje
Support Corvetteforum!
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Cost effective would be to use the 18/19 combo. 295's on the front and 345's on the back.
Old 04-30-2012, 07:41 AM
andy3101
andy3101's Avatar
I have heard great things about the new Michelin Cup ZP tires for the zr1/z07 19/20 inch set up.. Supposed to be a new compound than the old CUP tires (18/19 non ZP) and way faster...
Old 04-30-2012, 09:48 AM
doje
doje's Avatar
They won't compare with Hoosier A6's.
Old 04-30-2012, 11:50 AM
andy3101
andy3101's Avatar
I dare you to compare.... Don't want to start a battle, but would be interesting to compare A6 and the new CUP ZP 19/20
The new 19/20 CUP ZP tire is very new on the market, and a very different compound than the older CUP tire...
I know tire tests were done between the old cup tire and R6, times were the same, and the 19/20 cup ZP setup was several seconds a lap faster than both of these tires. (all tests were done on the same car, same day, same track etc...)
Old 04-30-2012, 01:13 PM
doje
doje's Avatar
Maybe, but the R6 also sucks for autocross. They don't get enough heat fast enough and don't get sticky enough. If the OP was looking to do track days, maybe there would be an option. However, for autocross, it's a different world.
Old 05-01-2012, 12:51 AM
acrace
acrace's Avatar
315s up front.
Old 05-01-2012, 12:55 AM
doje
doje's Avatar
Originally Posted by acrace
315s up front.
On a 9.5" wheel?
Old 05-01-2012, 08:22 AM
acrace
acrace's Avatar
On a 9.5" wheel?
Yep. Works for me (and the top C6 Z06s that run in SCCA). Although I did not due back-to-back testing between 295s and 315s.
Old 05-01-2012, 09:07 AM
doje
doje's Avatar
Pulling the sidewalls in that tight will cause crowning. I'm willing to bet that if you tested the contact patches, you'd find that the 295 has more contact - for less money.
Old 05-01-2012, 09:18 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
315s up front.
+1 on that... While i don't run a C6, just as Al pointed out, the top C6Z and GS guys are running them with no issues.
Hell, last year we had a guy in a C5Z running the 315s up front and 335s in the rear ( on the OEM 10.5 rear wheel ).
I would suggest if you DO run the big tire that you upgrade the front bar and endlinks. It will help quite a bit as well. Al, you agree on that?
Old 05-01-2012, 09:54 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
Worked well as rear tires on my C5 as well (18x9.5"). Crowning doesn't seem to be the issue that many make it out to be (how do you compare the two?), and as has been pointed out, many hot shoes run this setup.
Have a good one,
Mike
Old 05-01-2012, 10:16 AM
acrace
acrace's Avatar
Agreed. I took the 32 mm Addco bar off my C5Z and put it on my C6Z just before Nationals. No high buck Pfadt bar on my car yet.
To C6Z Autocross Tire Sizing info needed...
Quick Reply: C6Z Autocross Tire Sizing info needed...
