2001 rear tie rod end question
Old 05-07-2012, 05:16 PM
FL1BY
FL1BY's Avatar
Cruise-In IV Veteran
Default 2001 rear tie rod end question
Moog only lists one tie rod end for 2001 Corvettes, #ES2231RL. It appears to be abot 3/4 " shorter than factory installed one. Some vendors say that one size fits all corners and only lists one part number; Ecklers has "heavy duty front and rear, different part numbers.
I would like to use Moog products, but do they make a rear tie rod end? If they do, what is the part number?
Quick Reply: 2001 rear tie rod end question
