1/2" wheel spacers on a 2006 c6 trackcar.
Old 05-10-2012, 10:57 AM
frankgtb
frankgtb's Avatar
Default 1/2" wheel spacers on a 2006 c6 trackcar.
has anyone tracked successfully with good quality 1/2" wheel spacers like pfadt???
i know wheel spacers may or may not be harder on the wheel bearings and wheel studs
Old 05-10-2012, 11:25 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
there isn't a problem if you have good studs, although getting wheels that fit correctly is a better solution. 1/8" is all the spacer you car run without longer studs.
Old 05-10-2012, 12:27 PM
frankgtb
frankgtb's Avatar
ah thx david so just 1/2-3/4" longer studs?
Old 05-10-2012, 12:36 PM
Pfadt Racing
Pfadt Racing's Avatar
This.
If you're running a 1/2 spacer you're going to need to run 2.5" wheel studs. We have ARP Studs available, but they may require you to move to open lug nuts as well.
Old 05-10-2012, 12:40 PM
froggy47
froggy47's Avatar
I have a video on replacing rear studs with arp if you guys need to go there. I have run many billet spacers up to 3/4 " no issues. Recheck tq cold between sessions. Replace nuts at least annual.
Old 05-12-2012, 02:52 AM
frankgtb
frankgtb's Avatar
thank you sir would love to see the video
Old 05-12-2012, 08:57 PM
froggy47
froggy47's Avatar
Click on link in my sig.
Old 05-12-2012, 09:31 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I have run .850" it will change you spring rates too.
Old 05-13-2012, 05:35 AM
frankgtb
frankgtb's Avatar
where exactly is your sig?????
Old 05-13-2012, 01:42 PM
froggy47
froggy47's Avatar
It's under the blued out Vette picture move your mouse down about 2 inches where it says:
"Click below for my DIY videos"
Come on,
it starts with http://.......................................
Old 05-13-2012, 01:49 PM
froggy47
froggy47's Avatar
As a rule of thumb, what do spacers do to spring rates? Overall rates, the spring , the tire, everything that goes into overall rates.
I am guessing that moving the wheel out lowers the rate?
Not looking for # lbs, just what direction does is go higher or lower?
Old 05-13-2012, 02:14 PM
geerookie
geerookie's Avatar
Move the wheel out further and you have a longer arm therefore the effective rate will be lower.....more leverage.
Old 08-22-2012, 08:52 PM
frankgtb
frankgtb's Avatar
what make/brand of .850" wheel spacers and wheel studs????
Old 08-22-2012, 08:53 PM
frankgtb
frankgtb's Avatar
what make/brand of 3/4" wheel spacers and wheel studs????
Old 08-22-2012, 09:04 PM
Short-Throw
Short-Throw's Avatar
I ran longer studs, 3/8 spacers with my FIKSE wheels (18 x 9.5 & 18 x 12) on my street Z06 for 30K miles, mostly all track -- never an issue.
Old 08-22-2012, 09:30 PM
froggy47
froggy47's Avatar
https://southwestspeed.com/?sec=view...sssub=Aluminum
studs are ARP
The guys who sell wheel spacers for $100 a pair won''t like that link much, but I don't like overpricing much.
Old 08-23-2012, 12:36 PM
fcarga
fcarga's Avatar
studs are ARP
Thanks!
Old 08-23-2012, 12:54 PM
froggy47
froggy47's Avatar
Remember to ck torque COLD b4 sessions.
Old 08-23-2012, 02:10 PM
0Fikse Wheels
Former Vendor
Fikse Wheels's Avatar
Porsche 930 had 28mm spacers from the factory...
We do make all of our applications to fit without the use of spacers.
To 1/2" wheel spacers on a 2006 c6 trackcar.
Quick Reply: 1/2" wheel spacers on a 2006 c6 trackcar.
