Can C6Z06 shocks be used on a 2000 C5?
Old 05-22-2012, 12:11 PM
Tormania
Tormania's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Can C6Z06 shocks be used on a 2000 C5?
Can C6Z06 shocks be used on a 2000 C5? And if so how do they compare to Bilstein Sport Shocks?? Looks like I can get the C6Z06 shocks shipped 2nd Day air from Gene Culley for just over $300 and Bilsteins (if they can even be found in time) would be over $400 easy.
Old 05-22-2012, 12:18 PM
varkwso
varkwso's Avatar
They fit and work great.
Old 05-22-2012, 12:25 PM
Tormania
Tormania's Avatar
Cruise-In V Veteran
Just simple bolt on I assume, nothing has to be modified to have them fit?
Old 05-22-2012, 01:04 PM
Joy of 6
Joy of 6's Avatar
Yes, you got it
Old 05-22-2012, 01:06 PM
Alludc
Alludc's Avatar
yea, one of my fav mods. bolts right up, no mods and relatively easy to do quickly.
throw in a c6 grandsport fronts way bar too.
Old 05-22-2012, 03:32 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Bolts right on, but I would not say it is the same as a C6Z shock set.
I just pulled those off my Z and installed the Bilsteins and no, they are not the same shocks.
The Bilsteins not only use a different valve stack and piston design than stock, they also change extended and compressed lengths and bump stop placement.
As far as physically bolting them on the car...yes it will do that just fine...the same shock, not even close.
Old 05-22-2012, 04:25 PM
Tormania
Tormania's Avatar
Cruise-In V Veteran
I actually called LG Motorsports this morning and someone is looking for the one set of Bilstein Sports you have but are hard to find cause of the move. I would prefer to keep Bilsteins on the car as that is what I have run for years on it.
Anthony, maybe you would know just how much would a Bilstein Sport Shock need to compress before the bumpstop would be needed? If you've seen a couple of my other posts you would know why I'm asking. LOL!
Old 05-22-2012, 05:45 PM
Former Vendor
You know, I'm kicking myself for not measuring that when I had the car apart.
however, I believe I should be able to get some comparison's by the end of the week for you.
Old 05-22-2012, 07:37 PM
froggy47
froggy47's Avatar
Everyone should pay attention here.
You can bolt on some shocks, bolt on some sway bars, how about a few aero bits, maybe a wing, don't forget the shifter & cold air intake.
Will any of it work for how you use the car? Will it make the car perform better/worse?
Who knows? It's pretty hit or miss unless you are installing a tested package from a "known quantity" vendor. IMO.
To Can C6Z06 shocks be used on a 2000 C5?
Quick Reply: Can C6Z06 shocks be used on a 2000 C5?
