Any ideas on oil keeping oil cooler...
Old 05-26-2012, 10:12 PM
trapp
trapp's Avatar
Default Any ideas on oil keeping oil cooler...
I have a supercharged C6 Grandsport. I have a vented hood. I have a tough time keeping my temps down at the track... I ran 5w40 amsoil.
oil temps climbed to 275 etc and I have to back off... coolant temps around 210.
I was thinking of running thinker oil at the track...10w40 so at higher temps the oil won't thin out as much....
The intercooler for the supercharger blocks alot of the airflow.....
Any idea's
trapp
Old 05-27-2012, 12:37 AM
0Finspeed
Former Vendor
Finspeed's Avatar
Take a look at our oil cooler, it would be plug and play for your setup. Do a quick search and you should find plenty of helpful info on it.
Feel free to give me a call if you have any questions.
Old 05-27-2012, 10:37 AM
trapp
trapp's Avatar
Already looked at your cooler.......I need it asap...I have a two day track event at road of america 4th and 5th..
Tom
Old 05-27-2012, 12:49 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Any idea's
trapp
Actually a 5W-40 and 10W-40 will be the same at higher temps. Going to a thicker oil will not solve your issues, as in some cases I have seen thicker oil raise temps. An engine designed for a 30wt oil using a 40 or 50 wt will see increased friction and heat from the thicker oil.
To Any ideas on oil keeping oil cooler...
Quick Reply: Any ideas on oil keeping oil cooler...
