Worn Pads --- pedal height
Will worn pads affect pedal height ? say all 4 pads are very worn out.
I say NO, as the fluid will make up the difference.
Other say yes, and argue till the very end.
Based on my experience a new set of pads gives me a higher pedal, and as a weekend and the pads wear down so does the pedal travel further. Again, my experience after doing this for 2 years.
Yes, they do, because pads don't wear in a completely square manner. So the piston/backing plate fitment isn't completely flat, which causes the MC to have to push a small amount of fluid first to mate up the piston and backing plate, then to press the pads into the rotor surface.
HTH, and have a good one,
Mike
Mike
Received 8,919 Likes
On my C5 stock brakes the pads would taper when used on the track and I definitely got a long pedal. When I changed over to the Wilwood SL6 calipers the pedal stayed the same height. On the C6Z it didn't matter whether I was running the stock C6Z caliper or the Wilwood WA6 caliper the pedal has stayed at the same height.
Bill
Bill
