Iron block handling
Iron block handling
With all other things being equal, how noticeable would the difference in handling be between an iron block C5 and an aluminum block C5 (We can use 6.0 iron and 6.0 aluminum for reference). I don't mean anything about tire or brake wear, or fuel economy, just the difference in handling when cornering at speed. We can use a 1-10 scale, ex. if an aluminum block c5 rates a 6 how does an iron block c5 compare? Thanks, guys.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
FWIW, when I went the other direction (iron to aluminum block, lost 100#) on my C3, I couldn't feel any difference. (Hopefully I didn't waste the money, and the stopwatch notices the difference.)
Just my experience. YMMV
Yeah, I'm sure there is some impact from having +/-100lbs on the nose, but I'm just concerned about the way it feels. If you didn't notice it on the track, I doubt I would notice it on the street. Anyone else?
You might understeer at 97% of the limit you had with the Al block. I'm guessing. Also, unless you're racing for money or to have the best time possible for pride reason, I don't think it would make a big difference.
Received 8,916 Likes
It matters when you are pushing the limits of the car. Slight changes in car characteristics can make a difference. Say a novice is cornering at 40 mph on a tight radius corner which if the car was being driven at the limit could be taken at 55 mph. Adding 100 lbs to the front of the car more than likely will not affect the novice at 40 mph and he may still be able to get to 50 mph without noticing anything but he will never get to 55. An expert might get to 53 or 54 but they will never attain what the lighter car could do without compensating changes to the car.
Bill
Bill
Max G’s
Bill
Bill
Couldn't the extra weight increase overall wheel rate like what happens by adding a splitter or wing? Increasing wheel rate could help with turn in traction on the front tires allowing for a faster entry speed. Of course the adverse affect is hauling around more weight so it uses up some power.
Weight and downforce are the killers of speed.
long straightish tracts you want little down force
Sebring
Road America
VIR
tacks with long sweeping corners a moderate amount of down force
Mid-Ohio
Mosport
the Glen
short tight tracks high downfoce
Street circuits
Sebring
Road America
VIR
Mid-Ohio
Mosport
the Glen
Street circuits
