Talk about basic, radiator hose clamps?
Old 06-04-2012, 05:38 PM
froggy47
froggy47's Avatar
Default Talk about basic, radiator hose clamps?
I put a new radiator in & new Gates hoses, but I reused the stock (2004) clamps & have a small weep at the big lower hose at the radiator end.
I think it must be the clamp, the rad looks fine (new) so what do you guys use for good clamps, be specific, where do I buy it, etc.
Thanks!
Old 06-04-2012, 07:38 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I use the stainless steel screw type hose clamps. Get the ones that have the hex head as well as the screw driver slot on the screw, easier to tighten securely. Got mine at the local Auto parts store. The stock spring type clamps will eventually loose tension and cause leaks.
Old 06-04-2012, 07:39 PM
flink
flink's Avatar
ABA hose clamps are good: very beefy and you can put lots of torque into them without fearing that they're about to go "pop" and slip a thread.
Old 06-04-2012, 08:15 PM
froggy47
froggy47's Avatar
Old 06-04-2012, 09:30 PM
mgarfias
mgarfias's Avatar
the standard worm drive stuff is best. i've tried the fancy crap and its very size sensitive, generally a pain in the ***, and isn't any better at sealing.
Old 06-04-2012, 10:26 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I have changed radiators, and had the new fittings be slightly smaller than the OEM. I'd make sure the fitting is both sized correctly, and secure. If it is new aluminum tubing, you might try scuffing it a bit so the rubber hose will adhere better once clamped.
Double clamping is always an option, just use a few normal cheap clamps from Lowes, at least for your troubleshooting
Old 06-04-2012, 11:35 PM
travisnd
travisnd's Avatar
Had a few C5s over the years and done lots of tracking and never had a single issue with the OEM style clamps. I prefer them for working on the car. Easy to grab them with pliers.
Old 06-04-2012, 11:58 PM
froggy47
froggy47's Avatar
I'll take a green scrubby to it, but it does not look like the hose is slipping.
Old 06-05-2012, 12:00 AM
froggy47
froggy47's Avatar
I like the oem too, but maybe the Dewitts is a different OD than stock?
I don't recall how much I had to squeeze to get it on, I have the special pliers that lock the oem style open so it's EZ.
Old 06-05-2012, 12:06 AM
froggy47
froggy47's Avatar
Now that's a hose clamp.
Just what I was looking for and there's even a rock group named for the clamp:
Abba
I will pick some up & report.
Old 06-05-2012, 12:10 AM
travisnd
travisnd's Avatar
FWIW I had a Dewitts with EOC in my old Z06 and had no issues with the OEM hoses and clamps.
Old 06-05-2012, 12:12 AM
froggy47
froggy47's Avatar
Check this.
https://www.belmetric.com/
Old 06-05-2012, 12:13 AM
froggy47
froggy47's Avatar
How "old" were they, mine are 2004. What hose did you use? Could be a small difference between Gates & OEM?
Old 06-05-2012, 12:37 AM
travisnd
travisnd's Avatar
It was a 2001 Z06 that I had owned since 2003. I want to say the car had about 65,000 miles on it when I did the radiator/oil cooler install. I used the OEM hoses w/o issue.
On the current racecar I replaced the hoses because the car had 119k on it when I was prepping it. I purchased OEM replacements from www.gmpartshouse.com. If you're using a non-OEM hose that could be the issue.
Old 06-05-2012, 11:52 AM
froggy47
froggy47's Avatar
To Talk about basic, radiator hose clamps?
Quick Reply: Talk about basic, radiator hose clamps?
