14" Alcon Brake kit for sale cheap
This is a chance to save almost a grand off of a brand new in the box Alcon brake kit. This is a true race piece that you can run on the street, no compromises. It features
Advantage Extreme 6 piston monoblock calipers
Stainless steel pistons (not aluminum, which only belongs on the street)
No dust boots, instead a second inner seal to block road grime, which won't cook under heavy track use.
365mm x 32mm Alcon rotors
Aluminum hats and attaching hardware already assembled
Brackets
Alcon part number is BKF9751Y66 and retails for $4113.00
I would compare this kit to the Brembo GT-R at less than half the cost.
This kit will work great on a C5 or C6, Z or not.
Lines not included (since they vary depending on the car), but they are available from Hoerr Racing Products.
$3220
PM or call Tom if interested. 205-283-5158
Brackets
$3220
