BREMBO Corvette C6 Z06 | Grand Sport Front 6-Piston Fits Factory Stock Wheels
Old 06-12-2012, 06:03 PM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default BREMBO Corvette C6 Z06 | Grand Sport Front 6-Piston Fits Factory Stock Wheels
BREMBO Corvette C6 Z06 | Grand Sport Front 6-Piston Monoblock | 350x34 mm (13.8") | 2-Piece Discs Slotted
Front kit contains:
v Two 6-piston monobloc calipers (Black, Red, Silver, or Yellow)
v Street performance brake pads
v Two 2-piece floating type III slotted rotors 13.8”/350mm diameter
v Front Goodridge stainless steel braided brake lines
v Adapter brackets
These 6-piston monobloc calipers have more brake torque using a wide annulus, kit uses the VERY high thermal 34mm thick rotor ring with 72 vanes.
This kit is excellent for everyday driving and HPDE events
BREMBO GT SYSTEMS
System includes per axle
Calipers, Discs, Brake Lines, Caliper Mounting Brackets, and Brake Pads
Caliper Construction / Material
Cast, Aluminum-alloy, Monobloc
Number of Pistons
6
Piston /Design / Material
Dust Boot and Inner Pressure Seal
Caliper/Finish
Red, Black, Silver, Yellow
$3917.95
Old 06-14-2012, 05:49 AM
Former Vendor
St. Jude Donor '13
Old 06-16-2012, 08:00 AM
Former Vendor
St. Jude Donor '13
Old 06-18-2012, 05:57 PM
Former Vendor
St. Jude Donor '13
Old 06-19-2012, 07:35 AM
Former Vendor
St. Jude Donor '13
Old 06-20-2012, 06:56 PM
Former Vendor
St. Jude Donor '13
Old 06-22-2012, 04:26 PM
Former Vendor
St. Jude Donor '13
Old 06-30-2012, 08:10 PM
Former Vendor
St. Jude Donor '13
Old 07-18-2012, 05:01 PM
Former Vendor
St. Jude Donor '13
Front kit contains:
v Adapter brackets
BREMBO GT SYSTEMS
Number of Pistons
6
Caliper/Finish
http://www.xplosiveperformance.com/C...ed_p_2987.html
$3917.95
Old 07-21-2012, 05:56 PM
Former Vendor
St. Jude Donor '13
Front kit contains:
v Adapter brackets
BREMBO GT SYSTEMS
Number of Pistons
6
Caliper/Finish
$3917.95
Old 07-29-2012, 05:35 PM
Former Vendor
St. Jude Donor '13
68-82 C3 HIGH PERFORMANCE STREET SERIES Composite Leaf Spring Rear EZ Ride
Corvette Leaf Spring, Rear, Composite, EZ Ride, 1963-1982
Out Performs Factory Original
Better Ride Quality Than Original Spring
Rated @180 Lbs.
Replacement 1980-82
Soft Ride 1963-79
Our most popular spring bar none. The EZ Ride spring has the same rate as a stock 9 leaf spring - 200#'s. This is also the same exact spring rate that came out of the 81-82 Corvettes with a Composite Spring. The reason for the low spring rate is because of the springs high arch. Other composite spring need to have a higher spring rate because the arch is very low. This spring is an excellent choice for everyday cruiser. Owners with mid-years (63-67 Vette) love them. These also work great for the C3 (68-82) cars. Our 330 Spring is best for Big Block owners and is 10% stiffer than the OE 7 leaf steel spring.
http://www.xplosiveperformance.com/6...de_p_2889.html
$358.99
Old 07-31-2012, 05:48 PM
Former Vendor
St. Jude Donor '13
Front kit contains:
v Adapter brackets
BREMBO GT SYSTEMS
Number of Pistons
6
Caliper/Finish
$3917.95
Old 08-05-2012, 06:05 PM
Former Vendor
St. Jude Donor '13
Front kit contains:
v Adapter brackets
BREMBO GT SYSTEMS
Number of Pistons
6
Caliper/Finish
$3917.95
To BREMBO Corvette C6 Z06 | Grand Sport Front 6-Piston Fits Factory Stock Wheels
Quick Reply: BREMBO Corvette C6 Z06 | Grand Sport Front 6-Piston Fits Factory Stock Wheels
