Deglaze pads and rotors regularly? Yes/No? What about the transfer layer?
Old 06-20-2012, 12:39 AM
travisnd
travisnd's Avatar
Default Deglaze pads and rotors regularly? Yes/No? What about the transfer layer?
Researching my brake pad/rotor situation discussed HERE. I came across THIS article that suggests brake/rotor deglazing as regular pre-race maintenance.
I thought the whole idea was to develop a transfer layer between the rotor/pad and then let it ride?
Old 06-20-2012, 01:01 AM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
I think the glazing is the formation of various metallic oxides that don't support friction or heat transfer and thus remain on the surface and impede friction.
Old 06-20-2012, 06:43 AM
AU N EGL
AU N EGL's Avatar
stock car teams use new pads and rotors for each day of racing.
and If I am not mistaken the glazing is from too much heat or ie using the wrong brake pad for that friction level. too soft of a brake pad
Old 06-20-2012, 07:28 AM
Scooter70
Scooter70's Avatar
That's been my experience as well. The haze comes from severely overheating the pad and basically melting it. When that happened I used sandpaper and brake cleaner to "wet sand" the rotors and the pads.
Old 06-20-2012, 09:40 PM
froggy47
froggy47's Avatar
When there is "glaze" on either the pad or the rotor then the "transfer layer" of good pad material has been compromised.
Sometimes I get a little glaze spotting and then a few hard stops shreds it off, but if it's bad, like those pads in the pictures then a cleaning like they are doing is smart & then you put down a fresh transfer layer.
The only thing I would add is use garnet paper, not alum oxide or emory.
Old 06-20-2012, 11:21 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Pardon my ignorance, but what does the glazing look like?
Old 06-21-2012, 06:51 AM
AU N EGL
AU N EGL's Avatar
a shinny metallic glow / reflection
To Deglaze pads and rotors regularly? Yes/No? What about the transfer layer?
Quick Reply: Deglaze pads and rotors regularly? Yes/No? What about the transfer layer?
