C6 oil pan vs. C5 oil pan??
I spun bearing last weekend do to oil starvation. My understanding is that a C6 oil pan might help this problem. What do you think? It cost $400 for it.
thanks,
Steve A.
thanks,
Steve A.
Call Gary at ARE. He can fix you up!
Jim
Jim
pan
Accusump with LS6 and batwing
Dry sump with LS2/ LS3
You may survive with Accusump LS2/LS3 but grip (A6's, Goodyear AC's), high rpm's and any aero exacerbates the issue.
Dry sump is expensive but what is an engine or crash worth.
ARE??
thanks,
CI 3-5-6-7-8 Veteran
Nope... C6 pan is worse. How'd you loose oil pressure auto-xing? Usually it's sustained high speed sweepers that hurt these motors. LS1/LS6s are quite robust. I've been racing mine over two years (3k miles @ 122k miles now) and never had oil pressure issues. I run a LS4 high volume pump and Amsoil 10w40 FWIW; no accusump.
Premium Supporting Vendor
I suggest sticking with the stock LS6 pan or going to dry sump, and as mentioned in your other thread, for auto-x with aero, I'd consider a 30 grade racing oil.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
I think I have three years worth of data from Thunderhill in my '06 LS2 that clearly show oil pressure through T2, a sustained left-hand sweeper, getting lower and lower. If I overlay that with my terminal velocity on the front straight it also gets lower and lower.
This is a car with no aero, on 275+305 R888s, with coilovers & swaybars.
New motor went in last summer...
You can find ARE at drysump.com. Using a accusump is a crutch that works for some. It will not work at some tracks. Tracks like Road Atlanta and Mosport will definitely have a problem along with Roval tracks. I personally know of more than a few aero cars that lost the engine at Road Atlanta and they had the LS6 pan and accusump.
by mountainbiker2
With an Accusump is there a kit you buy? I read some thing about manual or electric.
thanks,
Steve,
You can buy from Canton. I have used both manual and electric (on more recent cars).
One of the keys in making Accusumps more effective on LS engines is drilling the lifter trays and using restricted pushrods. I have had very good luck using an Accusump on LS6 and LS3 engines with using the above methods (i.e no blown engines). The main problem with LS engines, and more specifically LS2 and LS3, is oil pooling in the heads and upper portion of the engine.
This is also not to say that a dry sump is the real solution.
thanks,
Steve,
