Tool For Turning Engine Over
Old 07-07-2012, 03:54 PM
victorf
victorf's Avatar
Default Tool For Turning Engine Over
delete this post
Old 07-07-2012, 04:52 PM
sperkins
sperkins's Avatar
Originally Posted by victorf
That is beside shorten socket, box end, turning rear wheel and such.
Well you kind of eliminated the easy ones.
What procedure are you trying to accomplish? Valve springs?
Old 07-07-2012, 08:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
starter........
Old 07-07-2012, 10:54 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
For confined space on C5 & C6, what ingenious tool you come up with to turn engine precisely over to TDC?
TIA!
Actually, those that you identified as notwithstanding seem to work pretty well.
Old 07-08-2012, 11:16 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
key
Old 07-08-2012, 01:42 PM
sperkins
sperkins's Avatar
Compcams Trunion upgrade.
You don't need to rotate the engine to TDC to do that. Just remove the rockers and get to work. When you're done, just bolt them back down to 22 ft/lbs.
To Tool For Turning Engine Over
Quick Reply: Tool For Turning Engine Over
