Help with a C5R light weight hood
Old 07-09-2012, 11:34 PM
2002rich
2002rich's Avatar
Default Help with a C5R light weight hood
Before I go off and get this hood painted, I want to know what purpose the front tear drop scoop is used for? I have one on each side.
If I don't need it, then I will glass it in. I'm sure the real C5R used it to provide cooling to something under the hood but I don't know what
I can't imagine that it's to allow air into the engine bay
Also should mention that it is right where I need to install the front latch pins. Well just off center a bit.
What do you guys think?
TIA
Old 07-09-2012, 11:42 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Who makes that hood? Is that the waxer C5 west hood? Comes with little add-on thingies for the fenders to "complete" the fender vent look?
Old 07-10-2012, 12:41 AM
meldog21
meldog21's Avatar
It is there to allow air in. Where its supposed to go, I don't know.
Who made the hood?
Dog
Old 07-10-2012, 01:46 AM
2002rich
2002rich's Avatar
Who made the hood?
Dog
Don't know who made the hood; bought it off of craigslist; however, it's brand new and we took it right out the wooden crate, unwrappped it and loaded it into my pickup. Very lightweight and will need to pinned in all four corners.
I have seen pictures of a C5R and the hood has the same front scoops so I'm hoping someone can tell me their function.
Old 07-10-2012, 08:58 AM
RDnomorecobra
RDnomorecobra's Avatar
nice. I dont know the answer but there are a ton of pics of c5r's in various states of undress. I just tried cr5, c5r hood, c5r naca ducts. Keep searching, you may find a pic that helps answer your question.
RDnomorecobra
what did you pay for that if you don't mind me asking?
Old 07-10-2012, 09:37 AM
Cobra4B
Cobra4B's Avatar
It's a C5 West hood It's supposed to have little add-on thingies that stick on the fenders to complete the vents.
Old 07-10-2012, 12:33 PM
6SPEEDZ
6SPEEDZ's Avatar
On a C5R the NACA ducts feed the twin restricter kinsler
Intake. With a stock style intake it would be hard to use those.
Old 07-10-2012, 12:49 PM
MySR71
MySR71's Avatar
Were those inlets used to feed the engine intakes? Take a look at the picture here:
http://www.netcarshow.com/chevrolet/...llpaper_09.htm
It appears they feed the orange tubing which is connected to the restrictors, then on to the intake manifold. Although from a model, this link has some interesting pictures:
http://www.diecastfast.com/diecast/DCF/CTGY/RVC5R01
I thought that the hood was by these guys:
http://www.c5westonline.com/catalog/...products_id=28
Old 07-10-2012, 04:38 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
TIA
I guess I am looking at this hood correctly and their are two big scoops after the center louvers? Yes/no?
Old 07-10-2012, 08:32 PM
2002rich
2002rich's Avatar
No those are heat extractors for the wheel well. Yep you would have to cut or at the very least drill holes to allow heat to be extracted thru the vents. Not planning on doing that for now.
Old 07-10-2012, 08:33 PM
2002rich
2002rich's Avatar
Sent PM
Old 07-10-2012, 08:38 PM
2002rich
2002rich's Avatar
Turns out I don't need them because I'm not running a C5R intake.
Old 07-10-2012, 08:39 PM
2002rich
2002rich's Avatar
Thank you very much
2002rich
2002rich's Avatar
Thank you
Old 07-10-2012, 08:51 PM
2002rich
2002rich's Avatar
Default Closure on C5R hood
Thank you everyone for your comments and clarification. I now know what those front vents are used for and as a result, I can remove them with confidence.
The other thing I would like to mention is....yes it looks identical to the C5West hood but with one difference, mine weighs 13lbs and will need to be pinned.
Old 07-10-2012, 09:01 PM
db2xpert
db2xpert's Avatar
That's an optical illusion John.
Joel
To Help with a C5R light weight hood
Old 07-11-2012, 02:14 AM
meldog21
meldog21's Avatar
I don't see any vents or "holes" in that picture of the underside of the hood. Are there vents, or do you need to cut them?
Dog
Old 07-11-2012, 08:18 PM
2002rich
2002rich's Avatar
Dog
Yes all of the vent slots are open. The photo position does hide it though
Old 07-16-2012, 11:57 AM
z060ntrack
z060ntrack's Avatar
Those NACA ducts are facing the wrong way
Quick Reply: Help with a C5R light weight hood
