Tracks with noise restrictions
Old 07-11-2012, 05:00 PM
JohnAlley
JohnAlley's Avatar
Default Tracks with noise restrictions
Starting to see more and more tracks having restrictions on the noise level from the race cars. I also do some auto-x with my TTS car and some of the locations require closed exhaust. What is available that can be slipped into the exhaust for those tracks or locations that require closed exhaust but then removed for all the other "normal " race tracks.
Old 07-11-2012, 05:17 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Check out the Super Trapp muffler systems. They have discs that can be added or removed to vary decibel level output of your car. They seem to be good at quieting without causing too much backpressure.
Old 07-11-2012, 05:50 PM
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
AMP and Roebling are the two I see that can be problematic in my area. Some guys are rigging blocker plates or some goofy looking tundowns (turnaways) to deflect from the booths. Others either lift at the booths or change exhaust completely for certain tracks.
To Tracks with noise restrictions
Quick Reply: Tracks with noise restrictions
