New hubs for C5 Corvette
Old 08-14-2012, 01:56 PM
JohnAlley
JohnAlley's Avatar
Default New hubs for C5 Corvette
I think it is time to replace the hubs on the C5 race car. I am not the best "wrench turner" in the world, is this a project that an average person can do?
Old 08-14-2012, 02:06 PM
RX-Ben
RX-Ben's Avatar
Very easy up front, a little more involved in back, but still easy.
If you have the stock fasteners, you need the weird T55 Plus size bit, IIRC (though double check).
Old 08-14-2012, 02:20 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Go SKF, John. Your aero is now making it a little more tough on 'em. Winning TT's costs, you know. Give me a holler if you want me to talk you through it.
Old 08-14-2012, 03:10 PM
meldog21
meldog21's Avatar
Just did this job a couple days ago.
The only difficult part(s) were:
Getting the axle nut off/on -lots of torque.
Man handling the axle and ball joints into place.
Needing unusual tools like the large torx and a 33mm socket.
Dog
Old 08-14-2012, 03:17 PM
RX-Ben
RX-Ben's Avatar
There are a few how-tos of this in the tech forum. Regarding the rear lower bj bolts, I think it is significantly easier to remove the upper bj nut so that you can tighten the lower bj nut, install the axle, then tighten the top bj nut. Otherwise you need to fool around with a cut allen key to tighten the lower bj (there is very little clearance btw the halfshaft and the lower bj) - which is a pain and you might strip the threads. Removing and then fastening the upper bj nut adds a minimal amount of time (5min?), though you will need a bj popper (NOT a pickle fork).
Old 08-14-2012, 04:01 PM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
call if you need any John...
Old 08-14-2012, 04:53 PM
PushinTheLimit
PushinTheLimit's Avatar
You can get one of those at a local parts store. I got mine at an Advanced Auto for maybe $20 and it's well worth it. I'm not a great mechanic by any means, but I was able to do my hubs without too many problems... biggest thing I ran into is loosening the bolts because of how tight they were.
Old 08-14-2012, 04:55 PM
0JDP Motorsports
Former Vendor
JDP Motorsports's Avatar
St. Jude Donor '12
The installation is pretty straight forward. I would also suggest going with the SKF set up. Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
Old 08-14-2012, 05:47 PM
froggy47
froggy47's Avatar
I did some videos click below & search my channel for corvette
To New hubs for C5 Corvette
Quick Reply: New hubs for C5 Corvette
