Igntion Power Wire - Which one is it???
Old 08-22-2012, 04:35 PM
ccw
ccw's Avatar
Default Igntion Power Wire - Which one is it???
Can anyone please tell me where the ignition power wire is on the C6? Which wire specifically provides the power to the ignition systems/coil packs? Location and/or color of wire would be greatly appreciated!
Thank you!
Old 08-23-2012, 01:23 AM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
What year? On an 08 ZO6 for example it is a pink wire from the ignition 1 relay. Fuse 12 20 amp for the odd# coils. Fuse 16 20 amp for the even # coils. Under hood fuse box...
Quick Reply: Igntion Power Wire - Which one is it???
