What effect does rear toe out have?
Track Junky
In my quest to figure out why I was having AH issues, I recently discovered that I actually had toe out (on the order of 5/8"!) during my last track day. I must have been so flustered trying to chase the problem that I wasn't looking at the inches and only focusing on the 1/23 increments. It must have happened during the camber kit swap. Read below for more information.
http://forums.corvetteforum.com/auto...-opinions.html
Could this have been the cause all along? Notice the pics of the rear tire wear (a dead ringer for toe out) in the pics. Would the significant toe out have made the car so unstable that AH would have engaged for the entire corner? How could I have been so stupid...
Any input is appreciated.
Rear toe out of any amount is IMO the worst possible mistake in alignment and makes for a very unstable car.
I think I touched on that in post #11 in your other thread.
Received 1,751 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Toe out would make it very very loose and hard to predict. Not to mention 5/8" is a LOT!
Track Junky
I must be the world's worst mechanic! I guess feeling hurried led to make the rookie mistake of looking at the hash marks between the inches and not looking at the actual inch value. I setup the car for the track between 13 hour shifts and had very little time to check and recheck like I usually do. Family duty didn't help much either...
I know that rear toe out makes for an unstable car and this may confirm that, coupled with the inside edges of the rear tires wearing significantly.
Man, I really need to get my head out of my butt and give a track setup the time it deserves.
When I go on track with others I am always thinking, is my car right & what about everyone else? Did they (or their mechanic) do a great job or did they have a bad day. Makes ya think.
Track Junky
You won't do it again, we all slip up on occasion. But something you are going to pilot @ 150 or so with others around needs good focus when it's prepped.
I don't normally make mistakes like that, but it is certain that I won't do that again!!!
i had 1/8 toe out and it was a wasted weekend with lots of spins. Aim for 1/8 toe in.
Track Junky
Good lesson learned...
Just for the benefit of everyone with a check list, am I right in thinking that one can visually SEE that much toe?
I know the body work on Corvettes is not that accurate, but I don't think they stink. When I stand over the wheel and look how it lines up with the body...I can see my toe in (per spec last time it was aligned) for the rear wheels. Front looks a little toe out but is supposedly zero toe.
The only intensional toe out I have ever put into a car is for the front for an autocross c5z06 that we ran one year to get better corner transitions. It worked well for that car on a very tight course. of course it was a little scary to drive on the roads at speed.
I bought a used C6 Z06 and found that it also had a little toe out in the rear and it almost wrecked me on an highway entrance ramp. Thank god for the nanies. saved my bacon. I also did not know what the problem was until I decided for other reasons to add camber to the front and found I was .5 toe out in the rear! car was completely different after this fix.
I wouldn't beat yourself up for it too bad. Glad you made the change and its wont be a mistake you make again!
Good luck.
Good luck.
Track Junky
Track Junky
It is called "Toe Steer" when you have rear toe out and that is exactly what happens.
Jim
Jim
No,
You can see 1/16 toe trust on the rear.
Stoop down behind the car....sight in the rear tire sidewall to the front tire sidewall. A 1/16 difference at the rear equals .259 at the front.
If you see a quarter inch difference from one side of the car to the other on the front tire, that is 1/16 of an inch on the rear tire.
No,
These sightings do not set the toe. It only tells you if the thrust is off.
If your toe is correct, it lets you check it in an instant.
Sorry for the spelling above.
