C5 Z51 Alignment Specs for Autocross
I have a 2000 C5 Z51 with stock alignment. I'm wondering if I should get it set up with the C5 Z06 alignment or a custom alignment. I'd like to get a good alignment for autocross, but also be ok for drag racing and the street. This isn't my daily driver, so I don't put a lot of miles on it. The current alignment causes the inside of the rear tires to wear faster.
Current Suspension Set-up:
C6 Grand Sport shocks all around
T1 front sway bar
C6 Grand Sport rear sway bar
C5 Z51 springs all around
Street Wheels & Tires:
275/40R17 front on 9.5" wheels
295/35R18 rear on 10.5" wheels
T1 front sway bar
I have a 2000 FRC aligned for auto-x. Everything I know about autocross alignment makes me think it has nothing in common with drag racing alignment, which I know absolutely nothing about. Auto-x optimizes for best lateral grip with lots of camber front and rear. Camber in the rear would seem to hurt longitudinal grip, which I'd think most important for Drag racing. Auto-x optimizes for great turn-in at the expense of stability, often with toe-out in front. Doesn't seem like compromising high-speed stability would be the way to go for drag racing. Auto-x optimizes for good power-down coming off slow corners, usually with higher amounts of toe-in at the rear. No apparent need for that for drag racing. It will just waste power in a straight line. So, the wish to do both types of racing with the same alignment may be a problem. Generally, the stock alignment (low camber, low toe in any direction front or rear) would seem to be a lot better for drag racing. (I'm sure it can be tweaked for drag racing.) Anything you do for autocross is going to move away from that, I think.
So the car will go straight down a crowned road, is my guess. Some aligners adjust for crown with unequal front caster that works because usually the driver is by himself and compresses one side more.
The Z06 alignments quoted above are very tame for autocross work. Avizandum's numbers are conservative for autocross, maybe just the right compromise you need.
I had to move my front subframe to get -2.5 on each side. Limited to -2.1 before doing that.
Camber: current is balanced front-to-rear, suggested is more in front than rear - induces oversteer
Caster: current is less than suggested - induces oversteer
Front Toe: current is toe in, suggested is no toe - induces oversteer
Rear Toe: current is no toe, suggested is toe in - induces understeer
It seems that all the adjustements except rear toe are going to induce oversteer. Is this going to be a big enough difference that I should plan on getting a stiffer front spring?
From my perspective, I would go with what avizandum suggested. It's a good starting point for a street driven/autocross car. My semi-dedicated autocross cars have a lot more negative camber up front and a touch more negative in the rear than his suggestions. But I'm willing to live with increased tire wear for better autocross performance, and I haven't hit the drag strip with my cars in a few years.
My remarks on your above comments:
Caster - I like to go with as much positive caster as I can. It has the effect of adding negative camber at high steering angles. Autocrossing has a lot of high steering angle inputs, as compared to track session.
Front toe - You can always change toe really easily. I'd align it at zero toe and then you can always adjust one flat at a time to suit your preference.
Front camber - I personally like as much as I can get (within reason, like -2 to -2.5). Autocrossing has, as stated before, a lot of low speed, high angle corners. You need front negative camber to have the front end bite.
I doubt that anyone can give you an idealized setting on the 'net, especially given that you've got some light mods and you didn't post if you run R compounds or not. Every course is different; different clubs and different parts of the country have huge differences in course design and philosophy.
Have fun!
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
On the front, toe out to 'turn in'. With toe out, the inside front wheel is scrubbing a bit while turning which helps the turn in with the induced yaw effect.
My 2 cents worth on C5 auto-x alignment
I've noticed that if you don't have the grip of a good tire, you can hurt yourself with too much negative camber. Use a pyrometer and if you are running hot only on the inside edge of the tire after a run, you may have too much neg. I think a good starting point is perhaps 2 deg neg in front. Multiply that by .75 and you have 1.5 neg in the rear. As for toe, I like a little out in front. I may toe it in a hair at the rear. All this is with my 180 lbs sitting in the car and a full tank.
I'm setting up my FRC this week. I'm gonna do some track trials and auto-x.
