Shop for Camber Plates Alignment in Portland Or. ?
Hi Gents,
Looking for a proper race or know-to-be-able-to-handle-it shop in Portland Oregon to re-do the alignment and corner weight of my c6 with pfadt camber plates and shims kit.
Went to my local shop last time and they did install and align to about 2deg front and 1.3 back but want more camber and right now the left front upper arm mounts are against the chassis without any shims or washers while the right has at least a couple shims on both mounting locations...
I know a difference in shim numbers is possible but should be able to get 2.5deg on each side in the front with that kind of camber kit no ?
Any thoughts ? Know a good place ?
Cheers
O
Cheers
O
Racetech Motorsports can do corner balancing. The best track aligner that I know is Garth at A N T Tire. Both of the businesses do this work on my car.
Highly recommended.
Highly recommended.
