EVS R4 Race Collar
Old 12-16-2012, 08:16 PM
383's Avatar
Default EVS R4 Race Collar
Anyone have experience with this collar?
http://www.saferacer.com/evs-r4-race...productid=2523
I plan on keeping stock seats/belts for now but I want some on track safety for my neck.
How about this sucker
http://www.saferacer.com/team-valhal...productid=2352
Old 12-24-2012, 03:24 PM
383's Avatar
Anyone use collars with stock seats and belts?
Old 01-23-2013, 05:46 PM
383's Avatar
So.... is that a no?
Old 01-24-2013, 08:54 AM
el es tu
el es tu's Avatar
I dont think anyone uses neck supports with 3 point belts...
I like the Valhalla - the pricing is significantly lower than a HANS branded device
Old 01-24-2013, 06:14 PM
Crepitus
Crepitus's Avatar
Sombody was posting about using the same collar in their race car as while instructing. It was this board but I cant rember the thread, seems like it was about collars. wish I could be more help
Old 01-24-2013, 09:05 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,929 Likes on 5,333 Posts
If you are going to use stock belts then go with this unit from Simpson:
http://www.saferacer.com/simpson-hyb...productid=2296
It is SFI rated and those others aren't rated. They don't even look safe. If you watch a crash test video of a dummy with a HANS device you see how it and the one above work. They keep your head on top of your neck by restraining the forward and upward movement of your head. They can also restrain side movement. From what I can see neither of the two you were looking at can do that.
http://www.hmsmotorsport.com/docs/Cr...thout_HANS.wmv
Bill
Old 01-25-2013, 07:13 AM
383's Avatar
[QUOTE=Bill Dearborn;1582936590]If you are going to use stock belts then go with this unit from Simpson:
Thanks that looks better and it looks as if I could use it with a harness if i ever go that route.
To EVS R4 Race Collar
Quick Reply: EVS R4 Race Collar
