How many track days between flipping R6 tires?
Old 12-18-2012, 03:45 PM
urslooow
urslooow's Avatar
Default How many track days between flipping R6 tires?
I drive in advanced grp in s fla and do 5 25 min sessions of hpde on Hoosier r6 tires. I usually remount turning the inside of tire to be on outside after 3 trk days, what do u guys do? I also chg right to left tires betw events
Old 12-18-2012, 03:59 PM
RX-Ben
RX-Ben's Avatar
Depends on your camber, bushings and driving style. But whenever you see a decent bit of wear on the outer shoulder is the easiest guide. I wish Hoosiers had squarer shoulders like BFGs.
Old 12-18-2012, 05:37 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I usually flip them after the 3rd event and they are done by the 6th or earlier depending on tracks run.
Old 12-18-2012, 07:14 PM
urslooow
urslooow's Avatar
I was gonna flip after 2, but I guess I'll keep it at 3 events. Mine were done after 5-6 events as well
Old 12-18-2012, 09:07 PM
froggy47
froggy47's Avatar
I go by the wear pattern, not # laps.
Old 12-18-2012, 09:09 PM
NVR2L8
NVR2L8's Avatar
I flip from side to side after each day, and flip on the rims after each 2 day event. If I am running the same size on all 4 corners, I also flip from front to rear.
As mentioned above, it all boils doen to monitoring the air pressure and wear rate. These factors will be determined by the camber, driving style, the track and surface, etc.
Old 12-19-2012, 09:52 AM
urslooow
urslooow's Avatar
Have -3 camber in front zero toe. max pressures are about 37-38 psi. tI've been getting pretty even wear waiting 3 days
To How many track days between flipping R6 tires?
Quick Reply: How many track days between flipping R6 tires?
