Diff fluid change question
Old 12-23-2012, 05:44 PM
Toilets
Toilets's Avatar
Default Diff fluid change question
I ran a full autox season and 2 hpde events last year on amsoil diff fluid.
Is it time to change for this season or am I ok for another season?
Old 12-23-2012, 06:07 PM
JDIllon
JDIllon's Avatar
You should be fine! Just check the level to make sure it is topped off. JD
Old 12-24-2012, 08:33 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
A few quarts of fluid is cheap insurance. Diff's cost $$$$$. Don't neglect your tranny. Open the fill plugs take some out if the fluid smells burnt or funny change it. If its very dark change it. Since your that far along change it. We change our tranny and diff fluids on a regular basis and we change our customers fluids on a regular basis. The fluid changes will depend on what fluid they are running, track cars only that we have stepped the fluids up not as often as street/track cars that use OE replacement fluids. Now most our cars run Sebring, Road Atlanta, Miami Homestead, VIR, Barber.
Old 12-24-2012, 08:35 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
AMSOIL rates the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT) for 50k miles in severe service. Based on that and given your mileage, you should be fine to use it another year.
That said, I think the fluid see's pretty high temps at the track (not so much an auto-x) as well as pretty high shear forces - so I change mine once at the start of every year.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 12-24-2012, 02:25 PM
froggy47
froggy47's Avatar
I do mine every year. Plus tranny. Plus ps fluid.
Old 12-24-2012, 02:54 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I use Redline Synthetics for both tranny and diff on my car and run 10-12 track week ends a year + 5-7K street miles. No problems after 8 years of this abuse. I only change once a year at the end of the season. You should be good to go for quite some time. IMHO unless you are an extreme duty racer, most folks change the fluids too often wasting money.
Old 12-25-2012, 07:46 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I'm also an Amsoil user and couldn't be happier with the products!
I use Severe Gear 75W-90 in the diff, Torque Drive in the trans, the Series 600 Racing Brake fluid, and their Power Steering fluid. I also use Amsoil 15W-50 Dominator Racing Oil, the WIX oil filter and their Coolant Boost. I check the condition of the fluids about twice during the season, and flush the fluids annually (except the engine oil which I change after every other event, and the brake fluid which I flush about 4 times/year).
I'm thinking about changing to their 75W-110 diff fluid next season.
As you can see, I'm a firm believer in the Amsoil Product line!
Hope my .02 helps!
Bill
To Diff fluid change question
Quick Reply: Diff fluid change question
