I need some more headroom
Old 12-28-2012, 07:19 PM
C5ZEE06
C5ZEE06's Avatar
Default I need some more headroom
I'm needing a bit more headroom in the C5 coupe with helmet on.
How much additional can be gained by removing the headliner and padding near the hoop ?
Old 12-28-2012, 09:43 PM
MJM
MJM's Avatar
Have you tried a race seat mounted with Hardbar rails? Gets your butt on the floor.
Old 12-29-2012, 01:13 AM
jawfixer
jawfixer's Avatar
Headliner removal--1+inch and custom seat mount on floor will definitely add more head room. I am 6'2" and needed extra room.
Old 12-29-2012, 10:22 AM
C5ZEE06
C5ZEE06's Avatar
I have a custom mount for the Evo that puts my butt pretty much on the floor already - but can still use a bit more. if there is 1+ inch in the headliner area..thats probably where Ill look next. Thanks guys !
Old 12-29-2012, 10:54 AM
GettReal
GettReal's Avatar
Yep, you will find an easy inch with the roof liner.Is that about what you need??
Old 12-30-2012, 10:14 AM
C5ZEE06
C5ZEE06's Avatar
One full inch would be just about right !
Not thrilled about performing the surgery on the liner / ceiling padding needed to get this Xtra clearance on my street / track car - but I really need it.
The problem area is limited to the overhead hoop area where the ceiling / underside of the cabin roof drops down that inch or so. Has anyone removed the padding in this limited area to get more helmet clearance ? how difficult can it be ?
Old 12-30-2012, 10:47 AM
GettReal
GettReal's Avatar
I went and dug out my roof liner so you can see the underside. Its not that removing the padding is hard but that area is hard formed in that shape. You could cut out that entire area I suppose so you would be left with 1/2 a roof liner. Anyway, heres a pic.
Old 12-30-2012, 11:32 AM
C5ZEE06
C5ZEE06's Avatar
that photo is a big help. Thanks for posting. Looks like it would be easiest to simply remove the entire liner intact..rather than cut it up. Might even be able to re-install later that way.
Old 12-30-2012, 12:22 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
built a Gurney bump on my car,,,,or as on my other car,we cut out the floor and made a new lower one......
Johnny
Old 12-30-2012, 12:33 PM
GettReal
GettReal's Avatar
Happy to help and removing it whole is your best bet
Old 12-30-2012, 01:23 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Get a see through targa top. I'm 6,5 and fit.
Old 12-30-2012, 10:47 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
There is always this option.
To I need some more headroom
Quick Reply: I need some more headroom
