AiM Solo Test Drive Program
Former Vendor
Update: The registration is officially open.
Hey guys,
Happy New Year!
Just wanted to see if anyone here is interested in test driving the AiM Solo in 2013. Basically you would reserve a weekend window to use the AiM Solo. I will ship it to you for you to use on the weekend. When you are done, simply ship it back using the enclosed label.
All you will have to pay for is the shipping fee (round trip ~$25).
Info on the AiM Solo here: http://m-world.us/aim_solo_dl_gps_la...ta_logger.html
Let me know your thoughts.
Richard@M-World
Authorized AiM Dealer and Data Specialist
www.m-world.us
info@m-world.us
Will this work with any Apple products? It seems that most are only useful with PC/Windows systems. We need on that can be downloaded to an OS based system.
Richard Newton
Richard Newton
Former Vendor
http://store.apple.com/us/browse/guide/windows
Richard@M-World
www.m-world.us
info@m-world.us
I'll be at the track several times in the next two months. Shoot me a PM if you are still looking for a test dummy.
-Exclusively a Mac guy since 2002 and AIM/Motec data user. Won't ever turn a lap without my SOLO.
Former Vendor
Richard@M-World
www.m-world.us
info@m-world.us
Richard,
What a great program! A bunch of us in Socal bought solos and DL's to run in our racecars. Hope you can help put pressure on AIM. Why can my cheap OBD2 readers and Android phone with wifi OBD2 reader read my C5 ECU and SoloDL cannot?
2008 the obd protocol changed to the current standard SOLO DL reads. That means C6 corvette. But will the DL read the OBD2 data of ALL C6 vettes? If the answer is no can a 2008 ECU be swapped into a 2005 C6 and the solo DL work?
Richard,
Former Vendor
Richard,
Regarding C6: 2004 is when GM started transitioning from J1850 to CAN. This process did not finish until 2008, when 100% of its cars became CAN. Therefore, I suspect that some of the earlier C6 may still use J1850.
Here's how to check based on pins on your OBDII port:
If you have pins 2, 4, 5, 16, you have J1850.
If you have pins 4, 5, 6, 14, 16, you have CAN
Former Vendor
Update: I am finalizing the details of the test drive program and will contact those who are interested shortly. Thanks for your patience in the mean time
Richard@M-World
www.m-world.us
info@m-world.us
Richard@M-World
www.m-world.us
info@m-world.us
My understanding is that a 2006 OBDII unit or later is required due to data transfer rate.
This is the same for all of the direct OBDII connections by other data acquisition companies that I am aware of. I am positive for Racepak and in talking to Tim Anderson from Racepak, which is now MSD owned, there is no interest in going into older products (i.e. 2005 or earlier) to try to make this work. You need to adapt individual sensors. Also, in most cases oil pressure will not record to Data Recorders in 2006 Corvette or later with direct OBDII cable due to that function is apparently GM exclusive and requires a licensing fee.
Former Vendor
The unit is on its way to the first test driver. The following dates are taken.
2/8-2/18
2/22-2/25
3/6-3/13
3/21-3/25
5/15-5/21
5/23-5/27
5/29-6/3
2/8-2/18
2/22-2/25
3/6-3/13
3/21-3/25
5/15-5/21
5/23-5/27
5/29-6/3
Looking forward to it!
Richard,
My current data recorder is not working, so I will need to replace it. I have another event coming up in six days. Do you have the Solo in stock? Can you get it to S.C. Around Wednesday of this week?
Thanks, I have been following your threads since my times over on the BMW forums.
Former Vendor
Richard,
