Seat rails----help needed
I have a 09z. I have the sparco evo 2+ seats driver and passenger. I had just got 2 sets of the Hardbar seat rails and I think they are well made quality pieces but do not allow my seats to sit low enough therefore I can not move them as far back as I like either. Car has a 6 point cage so the tops of the seats are on the main hoop.
Any suggestions?? Any other companies make rails for this that will allow me to sit lower? I'm not looking for sliding rails. Fixed position is what I need.
Here's where data trumps my memory every time. I forgot I had to clear the seat belt anchors, so my seat is sitting on top of the rail as well. If you want to trust my memory a second time, I think I had to mount it that way so that I could get it more inboard as well. Otherwise the shoulder wings wouldn't clear the door (I still have all the door panels and drive this as a daily driver).
In the second photo you can see how far back my seats are and how high they are. They could go back a little more until they touch the harness bar, but the farther back you go the less height you have due to the sloping roof line.
Probably no help, other than maybe confirming your problem.
If you have enough lateral room, you can mount the seats like the last photo in these instructions: http://hardbarusa.com/uploads/image/seat%20railv1%206(1).pdf
This is how I incorrectly remembered my seat being mounted ...
Thanks for taking the time to post pics.
Mine are pretty much like yours. And I can not mount like the last pic in instructions because that pushed the rails out too far not allowing me to bolt them in car.
Any other nice seat rails available?
The hardbar rails worked for me because I could mount the seat inside the floor rails. My seat is almost on the floor. I also used eye bolts for the sub anchor attachment points so the belt anchors could be laid flat on the floor. Before I had the hardbar rails, I made a custom seat mount by modifying a sparco slider assembly combined with some angle iron. A little bit of drilling and welding was required, but my seat was also sitting very low with that setup.
I have my seats mounted INSIDE the rails. I did have to use a Dremel tool to enlarge one or two slots on the bottom of the seat rails to allow the hardbar rails sit flat on the floor. I also had to play with the thickness of washers between the seat and the uprights to get the right distance between mounting slots. My stock seat mounting studs were not square nor were they an equal distance apart so that made it a little more annoying. Lap belt mounting points are on the OUTSIDE of the seat rails and the sub belt mounting points are on the BOTTOM of the seat rail a couple inches in front of the slots that the stud extenders go through (had to drill a hole). There is a relief in the floorpan that will allow you to mount the sub belts to the bottom of the seat rail. My seats are Sparco Rev Plus and Corbeau FX1 Pro with 6 point belts in a C6Z. Seats are about 3/4" off the floor but could go lower if I wanted them to. Hope this helps.
Go to the link in post 10 that naschmitz posted.
The picture next to letter L in the instructions is how my seat is mounted. Sorry for the confusion.
That is exactly how my seat is mounted also. Uprights on the outside. But as even you can see in that pic, the bottom of the seat is touching the side rails therefore not allowing you to go any lower.
Ok that makes sense then. See with the sparco evo2 plus you can't do that. Seat is wider so it ends up being too wide and not allow you to get in the car and bolt down.
Too wide as in the seat itself won't fit in the car or the seat rail holes won't go over the studs? My seats aren't as wide as yours but I have quite a bit of spacers between the uprights and the seat body.
